Amico CUT50 Plasma Cutter - Review
   / Amico CUT50 Plasma Cutter - Review #1
goddom
Bronze Member
Flat Rock, MI
LS G3038H
If you are thinking about getting a plasma cutter I got the Amico CUT50 for less than $300 from Home Depot. But now that I have it I think it would have been cheaper to get it from Amazon for a bit cheaper (https://amzn.to/31EjQFf). It says it can cut up to 3/4" thick material. I have used it a few times now on a couple different projects and so far so good. I even tested it on 5/8" material and it cut it OK when I put new consumables on it and I tried 1" material but it was such slow goign I stopped. I was a little unsure how well it would work but I think its better than the $700 Harbor Fright one.
In the attachments forum I posted a thread about adding gussets to a TSC post hole digger and used this plasma cutter to cut out the gussets. Looking at the threads a bit more I think I should have posted that in the fixing DIY section. I also have a few other videos cutting up some old gas cylinder tanks for random projects.
Here I unbox the Amico: Unboxing - Amico Plasma Cutter - CUT 50 & Weld Table Project - YouTube
Here I cut 5/8" material and it doesn't go well at first until I switch out the consumables: Amico CUT50 - Cutting 5/8" and 1" Thick Steel Plate - YouTube
I hope you guys find this helpful.
   / Amico CUT50 Plasma Cutter - Review #2
I bought a Colossal Tech CUT50F with pilot arc off ebay for $309 with a small batch of consumables. Haven't cut over 1/4" with it yet and probably won't ever see the need. They claim it will cut up to 3/4" @ 7" per minute. I am on my first set of consumables. It had a guide wire on the tip that I burned up pretty quick. I chunked it since it was in the way.
New/Unused 20ft Bi-Parting Iron Gate (A44391)
New/Unused 20ft...
Unused Single Prong Kivel Bale Spear (A42021)
Unused Single...
New/Unused 2025 XZ20R Mini Excavator (A44391)
New/Unused 2025...
2014 UTILITY 53X102 DRY VAN TRAILER (A43004)
2014 UTILITY...
2020 BOBCAT S595 (A45046)
2020 BOBCAT S595...
Scag Turf Tiger 60in Zero Turn Mower (A42744)
Scag Turf Tiger...
