Aluminum Axle Housing on Smaller Tractors
   / Aluminum Axle Housing on Smaller Tractors #1
WVH1977
Platinum Member
Richmond, VA
Massey 2860M Cab, Massey 1E.35, Gravely Pro-Turn 560
Hello all, I have been looking at smaller 25 hp tractors to go with my big tractor for close to the house. A lot of them have aluminum housing in the rear.
Besides the lighter weight, has anyone actually broke the aluminum housing or had any issues at all with it? Is it something that should really cause any concern?
   / Aluminum Axle Housing on Smaller Tractors #2
Thought only John Deere had aluminum axle housings in their E series tractors? Any other manufacturers I’m not aware of?
I am looking at an Kubota LX2620 and I believe it has an aluminum axle housing. Did not have a magnet to check but all the info I find says it is.
   / Aluminum Axle Housing on Smaller Tractors #4
Pretty sure Kubota is all steel. Check it with a magnet. Can a Kubota owner chime in to verify?
   / Aluminum Axle Housing on Smaller Tractors #5
I’ve seen the aluminum axle housing argued before. Some say it’s better, others worse. In my opinion it’s a non issue either way.
   / Aluminum Axle Housing on Smaller Tractors #6
I don’t believe that Kubota uses aluminum axle or transmission housings, or any other company except JD.
   / Aluminum Axle Housing on Smaller Tractors #7
Yes, some Kubota tractors, particularly those in the L series, do utilize aluminum housings, especially for transmission housings. For example, the Kubota 3025E has an aluminum-cast transmission housing. This is in contrast to models like the L2502, which features a steel-cast transmission housing. The choice of material can impact the tractor's overall weight and the maximum size of attachments it can handle
willy
   / Aluminum Axle Housing on Smaller Tractors #8
These aluminum or similar metal housings are fairly common with Asian companies. They do that to reduce cost. When
When I was a manufacturing engineering manager manufacturing forklifts, we weren’t happy about the transition to pot metal cases. Nevertheless we avoided problems by carefully torquing all of the fasteners carefully to avoid cracking the cases.
It worked but took some effort.
   / Aluminum Axle Housing on Smaller Tractors #9
willy
I’m not aware of a Kubota 3025E model. That is a JD model number.
   / Aluminum Axle Housing on Smaller Tractors #10
What asian tractors use aluminum? Not Kioti
Kubota Engine w/ Generator (A49251)
Kubota Engine w/...
78in Kivel Bucket (A49251)
78in Kivel Bucket...
96in Large Capacity Bucket (A49251)
96in Large...
Club Car Electric Golf Cart (A48082)
Club Car Electric...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A45679)
2019 INTERNATIONAL...
3pt Nitrogen Applicator (A49251)
3pt Nitrogen...
