Alternator wiring John Deere 3040
   / Alternator wiring John Deere 3040 #1
otto1234
longmont,co
jd3040
Howdy,
Got an old JD3040 and I have alternator problems.
The alternator has 2 leads: a thick red one -I bet this is alternator output
and a more narrow gauge wire leading in to the cables entering the cabin.
I bet this is the field voltage.
This terminal reads zero volts when tractor is running. and I have battery voltage (12.3V) on t he alternator output so its clearly not charging.
Does anyone have a wiring diagram that shows where the field wire goes in the cabin?
I have problems tracing its origin and its got to be broken/disconnected/or...
thanks
Otto
   / Alternator wiring John Deere 3040 #2
:welcome:
Welcome to the forum from Alabama. Sorry about your charging problem. How long have you noticed this problem?
   / Alternator wiring John Deere 3040 #3
Small wire should go to your alternator/battery light. If alternator light bulb is burnt out system will not charge.
   / Alternator wiring John Deere 3040 #4
Most likely Zebrafive is correct. DOes your alternatorbattery light work in instrument cluster?
2006 TerraGator 8104 (A53473)
2006 TerraGator...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
STEEL WHEELS AND TIRES (A53843)
STEEL WHEELS AND...
Trommel (A52377)
Trommel (A52377)
John Deere BD1108 (A50123)
John Deere BD1108...
2011 New Holland B95B Cab MFWD Loader Backhoe (A53473)
2011 New Holland...
