alternator belt
   / alternator belt #1
offshorerivas
la blanca,tx
jd2040
morning
I have a jd2040 that the alternator belt can not be tighten further. it is at the end of the strap . the belt is not brand new but not a year old. the belt is from JD dealer
correct numbers on belt
   / alternator belt #2
Possibly wear on the pulley's over the years caused the belt to be loose? R73784 is the belt part no., right?
   / alternator belt
thanks for reply
jd catalog - # is t-20334 but now they sub #R97758 . the number you gave is different . lol now i am confused
thanks for help
   / alternator belt #4
1st thing that needs to be established is your tractors serial number & if your tractor has a 3 or 4 cylinder engine. Then the correct part number for fan belt can be chosen. Part # T20334 which subs to R97758 is for 2040 with 3 cyl engine below serial # 349,999. Fan belt for 2040 with 3cyl engine after serial # 350,000 is R73784. PS: I sold 2040 3 cyl tractors when they were NEW.
   / alternator belt
thanks tx jim
my tractor is under the serial #3449*999 ,maybe you tell me what the lever on right side under seat is.there are slots ,i belive there are 4 dents or holes
I am still new to tractors and learning . this is our 1st tractor thanks
   / alternator belt #7
R97758 is correct fan belt for 2040 <SN 349.999 with 3 cyl engine. Lever under seat is for draft control on 3 pt hitch. D=depth,L=load,L/D=setting in between L & D IE less sensitive than L
   / alternator belt
Tx Jim
this is offshorerivas with the 2040 loose alternator belt . the numbers on the belt are correct and go with the serial # under 349-999 what do you belive could be
the reason for the belt to be loose . It is tightened to the end of the strap .
thanks for your input
   / alternator belt #9
How many hours are showing on tractor speed-hour meter? Does the back of belt extend out past the belt pulley's when belt is installed? Have you checked number on belt not just on the cardboard holder?
   / alternator belt
the speed-meter does not work . the number on belt is correct for this tractor .
if i am understanding what you are saying the belt does not extend past metal strap that is used to bolt alternator when tightened . now that i am explaining this, could it be that metal strap was replaced with a different size.?
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
8-Shank Cultivator (A52128)
8-Shank Cultivator...
Landoll (A50657)
Landoll (A50657)
New/Unused 20ft Farm Iron Gate (A48837)
New/Unused 20ft...
