alternatives to hydraulic top link
   / alternatives to hydraulic top link #1
oldboyscout
ne PA
Kubota B2620
does anything exist that would work like a hydraulic top link, but without the hydraulics? I'm thinking along the lines of a bottle jack, or a ratcheting chain binder like this:
   / alternatives to hydraulic top link #3
If you dont want hydraulics, the conventinal screw style toplink is about the easiest thing manually. Okay, so it isnt fancy and doesn't ratchet, but it is the same as what you posted. A case of dont try to re-invent the wheel comes to mind.
And a bottle jack is single acting, so that wouldn't work either.
But if you are looking for something better and dont have the rear remotes, there is someting out there. The name of it slips me right now but it is a self contained hydraulic unit. Raise or lower the implement and open a little bypass valve to lengthen/shorten it. It is supposed to act like a shock absorber too. Bt someone else will probabally be along shorly with the name of it.
   / alternatives to hydraulic top link #4
Here is a link. And only 200+ posts to go through. Opinions vary.
http://www.tractorbynet.com/forums/attachments/174498-hydraulink-self-contained-air-over.html
that Hydraulink looks interesting, but I don't like the "air cushion. Sallyridesdad said he built a ratcheting top link and would use the chain binder idea instead. Looks like I have some R&D to do!
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
6ft Pull Type Hydraulic Dirt Pan (A51573)
6ft Pull Type...
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2015 JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
2015 JCB 525-60T4...
2023 JOHN DEERE 8R310 LOT NUMBER 203 (A53084)
2023 JOHN DEERE...
