alternative to position control
   / alternative to position control #1
cchoate
Near Buffalo, NY
Kubota GL3430 HST
Does anybody use something other than pc to keep their 3pt hitch implement at a certain height? I was thinking about hanging a small chain or something from one of the lift arms.
   / alternative to position control #2
Sure. They have a set-up for 9N-2N tractors that goes on the ends of the top link pin on the tractor. These plates are slotted so you can loop chains through them and down to the implements. Are you having a problem with your position control? They use them on the old Fords because they were only equipped with draft control.
The b7500 dosen't have pc and I found out that it would cost me over a grand to add it. The wife won't let me trade so I'll make some alternative. That's ok though, I'm very happy with tractor. Where do you find the set up for the 9n - 2n?
   / alternative to position control #6
My '95 B7100 was delivered with such a chain (I assumed it was standard equipment from Kubota). If I remember right, the manual said to use it when "transporting" implements in the raised position, but I don't know any reason it couldn't have been used as you are thinking.
   / alternative to position control #7
My '78 Kubota B6100 has a chain like that too. Like Bird's my owner's manual says to use it for transporting but I have used it with my rake as a "poor-man's position control".
   / alternative to position control #8
Anyone have a pic or illustration for this.. I'm having a hard time visualizing it.
thanks
Soundguy
   / alternative to position control #9
Check out this link for the Ferguson and Ford Position Control <A target="_blank" HREF=http://zanethang.com/>http://zanethang.com/</A>
I bought one last winter and installed it in a few minutes but then "misplaced" the instruction sheet so I had some difficulty with the adjustment. Zane emailed me back as soon as I asked him why I was having trouble and was very kind - did not tell me "there is no cure for stupidity" /w3tcompact/icons/grin.gif a phrase I find myself using more and more - he simply suggested a couple of minor adjustments and it works like a dream now.
For what it may be worth.
Bob
2011 PJ Tilt Deck Gooseneck Trailer (A50514)
2011 PJ Tilt Deck...
2016 Chevrolet Cruze (A50324)
2016 Chevrolet...
UNUSED FUTURE 71" CLIP ON FORK EXTENSIONS - PAIR (A51244)
UNUSED FUTURE 71"...
H & S High Capacity Hayrake (A50515)
H & S High...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
Danuser 3 pt Post Hole Digger (A50515)
Danuser 3 pt Post...
