Also need help with 1st tractor
   / Also need help with 1st tractor #1
rod1b
Mississippi
I have 26 acres in central Mississippi, about 13 acres in pasture and the rest is wooded. The pasture is fairly level. I have about a 1500 ft gravel driveway. I plan to build a house in the next year or so and have a baby on the way in August, so price is quite a concern to me. I would love to have a FEL but it is more of a want than a need at this time. I have looked at New Holland, Mahindra, Farmtrac, and Jinma. I really liked the New Holland TT45A because of price $12,000 and hp 42. I'm afraid of not being able to get parts for a Jinma years down the line. 35hp Mahindra and Farmtrac seem to cost about the same as the TT45A. All I plan to use the tractor for at this time is cutting grass, maybe a garden, and driveway maintenance. Do I need a FEL or 4wd? Thanks for any advice offered!
   / Also need help with 1st tractor #2
You don't really need 4WD...unless you decide on a loader. I don't think you see much snow.
Personally, I'd go for a loader...they do come in handy.
As far as your mowing, any of the machines will do the work...as 2WD or 4WD. You could pull a 7' or 8' rotary cutter.
I agree about your concerns about Jinma.
Personally, the New Holland looks pretty good...probably a little more HP then you need. I see that's 2WD...so maybe not optimal if you hook up a loader. Just make sure you get power steering, even if it is a 2WD machine.
Have you priced a Deere 990? Or looked at used machines?
Good luck!
   / Also need help with 1st tractor #3
I also would go with the loader, they just have so many uses that a tractor doesn't seem to be a tractor without one.
I would have no qualms about buying a Mahindra or Farmtrac, there are many satisfied users on this site of both tractors. I am also a JD fan and as Roy has said the 790 or 990 would be an excellent choice.
Good luck with the baby, I hope it arrives healthy and sound.
   / Also need help with 1st tractor #4
I have to agree with Roy.. for your listed tasks.. 2wd w/ power steering and a fel is better than a 4wd and no loader. The loader will open up a whole avenue for projects that you couldn't do without it. not having 4wd means that in some instances you may not be able to use the machine to it's 100% potential.. .. but the rest of the time for 'powered wheel barrow', lifting, and general scooping stockpiled materials.. it should do just fine..
Sounds like a great size of machine you are looking at in the CNH line..
Soundguy
2013 New Holland T4.75 Tractor (A52384)
2013 New Holland...
2021 JOHN DEERE 6130R LOT NUMBER 46 (A53084)
2021 JOHN DEERE...
Doosan Forklift (A51573)
Doosan Forklift...
UNUSED CFG INDUSTRIAL QK18R EXCAVATOR (A51247)
UNUSED CFG...
2024 JOHN DEERE 9R440 LOT NUMBER 78 (A53084)
2024 JOHN DEERE...
JOHN DEERE LOT NUMBER 122 (A53084)
JOHN DEERE LOT...
