Alphabet Soup
   / Alphabet Soup #1
Glowplug
Veteran Member
3rd Planet from the Sun
Kubota M7040HD
Can anyone help me understand the basics of trailer weights? In particular, I find all the different weight abbreviations very confusing. What is the difference between GVWR, GCWR, GVW, ETC.? Even if there is a good website that I can be referred to that would be helpful. I don't think there is a book "Trailers for Dummies" so any help would be appreciated. I am not unintelligent, but I just can't get a grasp on this. Thanks.
   / Alphabet Soup #2
I learned a lot about this back when we were camper shopping a number of years ago so here's my take:
Any time there is an "R" in the letters it's the Rating. Without the "R", it's generally the actual weight. "V" is vehicle, "A" is axle and "C" is combined. If you are planning a load you want to make sure you're below the indidual axle ratings, the vehicle rating for a truck load and the combined rating for a trailer. With a trailer, the tongue load should not exceed the vehicle rating number.
The rating numbers are found either on the door sticker and/or in the owners manual. You may need the axle code from the door sticker to use the weight tables in the manual.
So if your truck weighs 6000 pounds (Gross Vehicle Weight, GVW) and the GVWR is 8800, you'll be fine. One other number is the curb weight, which is basically the empty weight.
There's a lot more too it all, but that's a start.
   / Alphabet Soup #3
Empty, my truck weighs 7k. That is the GVR. It is a 2500 with GVWR of 8800#, that is what it the max or gross it is rated at. For truck and trailer or combined weight, it is around 20K. Keeping under these numbers I'm legal, Staying under the axle ratings and tires ratings is the most important to me. JC
   / Alphabet Soup #4
Whoops, no such thing as GVR, probably meant GVW for Gross Vehicle Weight.
The best website is RV.net where there are even more weight police than on TBN. The RV guys have at least as many issues with ratings as we do and they seem to be more willing to think about and apply the ratings rather than assuming, guessing, and estimating.
While it is confusing, the numbers game can be figured out and applied in black and white. Then you as the operator must decide if you want to use your equipment at 100% of these ratings or only partially load it (or overload it) according to your own safety margin or assumptions. The usual debates seem to stem from abuse and misuse of assumptions other than the factual numbers you inquired about.
   / Alphabet Soup
Well, I guess you caught me. Typo I guess. Thanks for the site. I'll check it out!
   / Alphabet Soup #6
He caught my typo I think. Anyway maybe you have figured out what all the abbreviations are for. JC
   / Alphabet Soup #7
I thought you might change your name to WarEagleRam after what happened :D :eek:
   / Alphabet Soup #8
If I lived in Auburn, I might pull for them. I live in Bama and pull for them. It is not Kubota tractors that make me hate the color orange. JC
   / Alphabet Soup #9
GVWR = Gross Vehicle Weight Rating, also called GVW = Gross Vehicle Weight, this is the maximum of a vehicle with fuel, passengers & cargo, it can be applied to either a trailer or a car/truck.
GCWR = Gross COMBINED Weight Rating. This it the maximum combined weight of BOTH your trailer and your tow vehicle.
CW = Curb Weight. This is the raw weight of the vehicle without passengers, fuel or cargo.
Payload Capacity. The maximum weight, including fuel and passengers, that can be carried inside a vehicle. It is the difference between the CW and the GVWR.
Realize that a 7000# GVWR trailer will NOT carry 7000#.
It will carry a payload that is roughly 5500# and the trailer itself will weight about 1500# for a total of 7000#. Also do not believe that there is any "safety factor" built into a trailer, most trailers are pretty cheaply built and have no such thing as a safety factor. A typical 16' trailer will weight between 1400# and 1600#.
  • Example 1: My VW Touareg weighs about 6486# when fully loaded that would be the GVWR. It has a curb weight of 5086#. That gives it a payload capacity of 1400#. It can tow up to 7700#. So a fully loaded Touareg + a fully loaded trailer will yield a GCWR of about 14,185# (but I cannot find an offical published GCWR).
  • Example 2: A Hummer H3 has a towing capacity of 4500#. It has a curb weight of about 4700#. It has a GCWR of 10,000. It has a GVWR of 6000#. That gives it a payload capacity of 1300#. So if you fully load your Hummer H3, you can NOT tow a full 4500# because you will exceed your 10,000 GCWR by 500#.
*** Payload capacity = the total weight of passengers, fuel in the tank, spare change stuck in the seat cushions and all the cargo you plan to carry, so if someone has a hefty wife and wants to pack a lot of gear, you may have to choose between the wife and some of the gear. :eek:
*** CW can be applied to any vehicle or trailer.
*** Do NOT assume that the towing capacity is congruent with the GCWR. It is very possible to overload your vehicle's GCWR if you are towing a full load and you have a full payload.
   / Alphabet Soup #10
And I always thought that Auburn was in Bama. I have been mislead.:eek:
2013 BMW X5 xDrive50i AWD SUV (A50324)
2013 BMW X5...
2017 John Deere TX Gator Utility Cart (A51691)
2017 John Deere TX...
2009 Chrysler Sebring LX Convertible (A50324)
2009 Chrysler...
2019 Chevrolet Tahoe LT SUV (A51694)
2019 Chevrolet...
2017 Ford Explorer SUV (A50324)
2017 Ford Explorer...
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
