Almost went off my bridge, into the drink
   / Almost went off my bridge, into the drink #1
SteveM
Upstate NY
Kubota B7100DT
So I was doing some last minute brush mowing last saturday before a haunted halloween hayride deep into my woods. it was cold and off/on rainy. On my way back to the house I have to cross my big stream - on the sturdy bridge I built 3yrs ago. Bridge is 16' accross, 5' wide with a center support, approx. 3' above the knee deep freezing water. Tractor is 42" wide at the rear tires, carrying a 48" brush mower (I did have my FEL on, so it was quite balanced) so it is a tight fit under the best conditions.
Any how it is a sharp turn and a steep little dirt ramp up onto the bridge, and as quick as you can say YIKES one of my rear tires lost traction, causing the lightened front end to slide sideways on the greasy wet bridge. Just like that one front wheel is off the bridge, and I am resting on the center of the front axle - loader hanging partly over the water, with one rear tire hanging above the slick dirt. In other words, about 1/2 pound from flipping into the water. WOW does that get your attention. /forums/images/graemlins/blush.gif
Slowly lowered the loader and brush hog, reverse low range with diff. locked to slide the tractor back off the bridge. I could not get that front wheel to hop back up on the bridge...
I have never come so close! And in an instant doing something completely routine!
Just goes to show how fast things can go to heck /forums/images/graemlins/confused.gif
   / Almost went off my bridge, into the drink #2
Yikes! /forums/images/graemlins/shocked.gif Glad everything turned out okay! Having something like that happen when you're all by yourself is a really lonely feeling, isn't it?
   / Almost went off my bridge, into the drink #3
Sounds like a 4 X 4 nailed along each edge to act as a "curb" would have prevented you from going off. Might be a worthwhile investment.
Bill Tolle
   / Almost went off my bridge, into the drink #4
Wow! I am happy to hear that it turned out ok. Thats a good reminder that you cant be too careful.
Mark
   / Almost went off my bridge, into the drink #5
Glad everything turned out OK.
Hope your tractor has a ROPS and that you were wearing your seatbelt at that moment!
If you get a chance sometime, could you post a picture of your bridge?
Again, glad everything ended up being OK...
   / Almost went off my bridge, into the drink #6
</font><font color="blue" class="small">( Sounds like a 4 X 4 nailed along each edge to act as a "curb" would have prevented you from going off. Might be a worthwhile investment. )</font>
That's what I'm thinking...
   / Almost went off my bridge, into the drink #7
I might even think about going up six inches or so. It can't hurt.
   / Almost went off my bridge, into the drink #8
Sounds like a predicament. Glad you are alright. Good lesson for everyone doing something similar, so thanks for posting.
How about fixing the ramp with some gravel, not dirt?
How about less of a ramp up to the bridge?
And/or a wider bridge?
Sounds like a bit of planning for your future is in order. This wake up call was a close one. /forums/images/graemlins/tongue.gif
   / Almost went off my bridge, into the drink #9
I call what happened to you Steve, "Close encounters of the unexpected kind." Glad it turned out the right way and that no damage was done to you or the machine. I would be looking at those 4 X 4s recommended earlier also.
   / Almost went off my bridge, into the drink #10
Or maybe angle iron bolted flat on one side of the angle so you didn't lose so much width.
John Deere 4650 Tractor (A53117)
John Deere 4650...
2015 Kubota KX71-3S Mini Excavator (A52377)
2015 Kubota...
2018 CASE IH 110N LOT NUMBER 207 (A53084)
2018 CASE IH 110N...
2001 AMADAS 2100 LOT NUMBER 251 (A53084)
2001 AMADAS 2100...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
2017 Ford F-350 Crew Cab Service Truck with Liftgate (A51692)
2017 Ford F-350...
