Almost lost it!
   / Almost lost it! #1
deputyrpa
Fort Ann, NY
2006 Massey Ferguson 3635 Cab
Phew! I had a close call this afternoon! I'm so sorry I did not take pics, but my farmer/neighbor was busy and I had no time to run 1/2 mile in snow back to the house to get the camera.
I was on my way to a far woodline in order to skid out some 12-14" pine I dropped this morning. I had to cross three 1-2' wide creeks in teh farm field raods to get to one of the trees. I used the snowmobile to find and cut them, so now was tractor time! Well, the last creek is a field crossing with no culvert. It's been forded for many years, and it appeared fine with no open water, when I scooted across it with the sled. This is a weenie little creek here. Approach and departure are 15% slopes.
Well, the snow is ~2' deep, but fairly hard. As I approached the crossing, I went slowly, and stopped, then inched forward. As soon as my front wheels got near the approach bank...squish, down the right side went, the front tire buried in wet clay up to the top! I surveyed the situation, and apparently I drove into an old rut with water in it that extended to under the rear tire too! The ground was frozen on either side of the front tire, and I could not turn it because it was buried. The tractor was listed about 15 degrees right, and I turned the wheels in low reverse but the right wheels went down even deeper, and listed further. I had to use the bucket to keep from tipping over, as the both left tires were off the ground, even out of the snow. I tried using the bucket to curl out, but the bucket just sunk right in the stream channel. I'm serious that I could have pushed the DK45 over with one finger. I stopped before it got worse and called my neighbor, who came over to bail me out with his big JD 4x4...again. He had to clear the 2' or so of snow for traction, so he could pull from the left. I was able to dig the snow out from under the left rear, which was up in the air, and push it down with the loader. Then, as I put full down-pressure with the loader, he dragged me out. No damage, no injury. LOT's of sweat!!
Needless to say first job in the spring is to install a culvert there!!
   / Almost lost it! #2
Well thats your excitment for the week,next week is coming!
   / Almost lost it! #3
Glad to hear it didn't turn out to be more serious.
You were wearing your seatbelt and the ROPS was in the up position... correct!?
I know the feeling, when I was carrying the 450lbs of truss 6' out in front of my bucket, with the bucket about 8' in the air. I was heading down and across a slight embankment, my lowside front tire dropped into a low spot in the lawn I didnt' see. At that point my highside rear tire had air under it and I could feel the tractor teetering :eek: that sent my pucker factor sky high. I was sure glad I was creaping along as slow as I could, in low at idle. SWMBO was watching and she did a bit of panicing herself. At that point I lowered the truss's to the ground, the rear tire settled back to the ground. :) I then backed up out of the low spot, lifted the truss's off the ground and proceded slowly around the low spot. No harm, no foul... lesson learned.
   / Almost lost it!
All safety apparati were deployed sir!
I already flopped the Jinma with a load of gravel and front tire in a soft spot. There was NO warning there. My pucker threshold is LOW!
   / Almost lost it! #6
Glad to hear it turned out well for you.coobie
   / Almost lost it!
Thanks guys....
It took some time for me to hop back on it after we hooked up the chain to drag it out. My sphincter was so tight I could have sat on a screwdriver.....
   / Almost lost it! #8
Thanks guys....
I feel your pain,a few years ago I was helping a neighbor out trying to plow his drive in a snow storm with my massey 1240 and almost rolled it on a steep hill next to his drive.With all the blowing and drifting of snow & being night time I lost where I was at.The pucker factor was great that night,I tucked my tail and came back when it was daylight.Better safe than sorry!!coobie
   / Almost lost it!
Smart move Coobie. Night is the worst time for exploring new places!
   / Almost lost it! #10
I tend to leave my bucket fairly low to the ground when going into unchartered teritory just in case.
Glad all worked out Deputy, you've got to be particularly carefull when alone and away from the house, out of shouting distance.
Just goes to show how fast things can happen.
Sounds like you were being cautious and it paid off, that's the key.
Glad you and machine came out unscathed.
Then again, maybe if you were doing 15 MPH you might have driven right over the gully and actually gotten your work completed :) :) .
Joel
2020 KUBOTA RTV...
(10) 20' Continuous Fencing Panels (A50515)
(10) 20'...
Komatsu Midi Excavator (A51691)
Komatsu Midi...
LOT LOCATIONS (A52141)
2016 John Deere 6155M (A50120)
2016 John Deere...
