Allow move when off seat TC34DA
   / Allow move when off seat TC34DA #1
6sunset6
Veteran Member
SE NY
NH TC34DA 34HP HST, 2 rear remotes, front diverter, loaded R4's
I had to do this, I cannot see the ends of the forks and have wrecked pallets.
I wanted to maintain as much of the safety aspects as possible.
I did not want to jumper out the seat and I did not want a toggle switch on the dash. I already have a diverter vale with push buttons on the joy stick so I just added another NO push button to the handle. Allows me to keep my hand on the joystick to move the forks while depressing the PB so I can stand up. The buzzer still works till I sit down. If I let go of the button while standing the 2 sec delay kicks in and the engine stops.
I ran the wires to the bottom of the seat , easiest place to find and attach the wires from the switch, I jumped pins 2 and 4 per the schematic and all that happened was the buzzer stopped. moved the wires to 1 and 3 pins and it worked perfect, Schematic has the pin no wrong. Unless I am a complete idiot. That can happen. Anyway I attached the schematic page in case anyone is interested. For some reason I had to zip it so you have to download it and open it to see it, I think,
   / Allow move when off seat TC34DA #2
That's a good way to keep the safety and have a temporary override. The seat switch was the first thing to get jumped on mine. I'm always getting on and off the tractor, and standing up and sitting down while maneuvering. Can't handle it shutting off every time.
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A53843)
2011 NORAM POWER...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A53843)
2019 GENIE GS-1930...
2015 DODGE RAM...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2012 Mack GU713 T/A Gardner Denver Kill Truck (A52377)
2012 Mack GU713...
