Allmost a cooked Kioti
/ Allmost a cooked Kioti #1
krazykioti
Frewsburg , New York
Kioti Dk45
I did something really stupid today . I was brush hogging my field and not paying close enough attention to my gages especially my water temp gage.
I had been mowing for about 3.5 hours while checking my gages periodically but not paying close attention.I noticed that my water temp was just shy of going into the red. I switched of my pto and dropped my engine down to an idle immediately. I wondered what would cause this. I got off my tractor and went around to the front. I noticed right away that
my radiator shroud was full of goldenrod dust. I immediately cleaned it out. The water temp started to drop gradually. I let the motor run at idle & let the water temp get back to normal for about 20 minutes before I shut it down.Even though the motor did not over heat I am somewhat concerned because it only has 112 hours on it.
Next time I will pay a lot closer attention.
Charlie
/ Allmost a cooked Kioti #3
Charlie,
It'll be fine,, no harm.
RedDog
/ Allmost a cooked Kioti #4
Charlie, you need to clean the screen in front of the radiator as well as the radiator itself, and the outside grilles.
I do this every time before or after using the tractor as it take very little time to clog everything up in things like cat tails, dog fennel and goldenrod.
I doubt you did any damage, but it's a good idea to stop as soon as you notice a lot of crap in the holes of the grilles.
You can use low-pressure air to clean the radiator being very careful not to hit the fragile fins. Too high air pressure can bend those fins, but the radiator needs regular cleaning or it will be harder to clean out as debris gets pushed into the fins over time. John
/ Allmost a cooked Kioti #5
I eliminated THAT particular problem by getting some nylon screen material and making a front end cover to keep the stuff on thwe outside of the tractor. I use bungee straps etc to hold it on. Make sure that the open under side in front of the radiator is covered too. I can now do my whole day of hogging without gettin "warm ". of course I have a cab... one can take that last comment 2 ways /forums/images/graemlins/grin.gif
/ Allmost a cooked Kioti #7
</font><font color="blue" class="small">( I can now do my whole day of hogging without gettin "warm ". of course I have a cab... one can take that last comment 2 ways )</font>
/forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Allmost a cooked Kioti #8
The goldenrod around here is just starting to bloom, however the worst to watch out here are the dog-fennel kooties, they will block a radiator in a heartbeat.
/ Allmost a cooked Kioti #9
I'm glad you boy's down south have them there dog-kooties. /forums/images/graemlins/shocked.gif
/ Allmost a cooked Kioti #10
We'll be more than happy to send some up your way! /forums/images/graemlins/wink.gif
/ Allmost a cooked Kioti #11
/ Allmost a cooked Kioti #12
Charlie,I did the same exact thing a year ago on my DK40 when it had about 100hrs on it,mine actually boiled over before I woke up.
I've got more than twice the hrs. on it now and it shows no signs that I did it any harm or good for that matter,****! it probably toughened it up.
By the way I'm not too far from you,wasn't Shane Conlin (Buffalo Bills) from Frewsburg?.....Mike
Yes ,
Shane was from Frewsburg. I believe he is down around Pittsburgh now. I think in the restaurant business.
Charlie
/ Allmost a cooked Kioti #14
Is there no prescreen over the radiator like on the Kubota and JD?
/ Allmost a cooked Kioti #15
</font><font color="blue" class="small">( Is there no prescreen over the radiator like on the Kubota and JD? )</font>
Yes, there are screens on the grill and a prescreen in front of the radiator.
But when brush mowing high field grass with seed/goodenrod Etc. they can still plug up and cause the tractor to overheat..
2020 DRAGON ESP...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
Sdlanch SDLL60 (A60463)
Sdlanch SDLL60...
GUIGONG CLG9035E EXCAVATOR (A62129)
GUIGONG CLG9035E...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
