Allis Chalmers WD45 Starter Trouble
   / Allis Chalmers WD45 Starter Trouble #1
Dakotacornman
AC WD45
I own a much loved and extremely dependable Allis Chalmers WD45. It is my go to for many jobs, and my dependable back up unit. Has always started easily. Changed oil and went to start, it gave a weak one turn over and then stopped cold. Weird! Battery terminals were cleaned, nothing. Battery is at 6 volts, so no charge needed. Engine cranks over with hand crank. Cleaned up the starter switch inside and out, nothing. Cables were a bit ugly, replaced, again nothing. Swapped out another starter and switch from a parts machine, and again nothing. No cranking at all. What could possibly be happening here?
   / Allis Chalmers WD45 Starter Trouble #2
Can you manually jump it with a 3rd battery cable directly to the starter primary ?
Just because the battery reads 6 Volts doesn't mean the battery can pass enough current to engage the solenoid & starter motor.
Check battery for water level. If it's low, you might have to completely recharge it. See if a golf cart battery is available, 6 or 8 Volts.
   / Allis Chalmers WD45 Starter Trouble #3
Sounds like a bad ground at the chassis end, either where the cable attaches to the chassis, or the starter mount. Starter grounds out through the starter case, so the mating surfaces need to be good and clean there too.
   / Allis Chalmers WD45 Starter Trouble #4
Check the battery voltage when trying to start. The battery can show good voltage with no load but may really go low with the draw of the starter. If you've added water and charged the battery it may be time to replace it.
   / Allis Chalmers WD45 Starter Trouble #6
6 volts doesn’t really mean much you need to put a load test on the battery and then decide what to do next.
   / Allis Chalmers WD45 Starter Trouble #7
By starter switch you are referring to this correct,
When you pull the rod is it pushing the button in far enough to
make contact?
Have you tried mashing down on the button by hand.
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2025 Future Stump Grinder Mini Skid Steer Attachment (A50322)
2025 Future Stump...
Super Material Lift MH1000 (A52748)
Super Material...
2015 Ford Transit 350HD Passenger Van (A50323)
2015 Ford Transit...
2016 Nissan Sentra Sedan (A50324)
2016 Nissan Sentra...
2014 Ford Taurus AWD Sedan (A50324)
2014 Ford Taurus...
