Allis chalmers HB112 wiring help
   / Allis chalmers HB112 wiring help #1
deans
Ontario, Canada
A/C c, Yanmar 155D, Kubota
I have been given a HB112 lawn tractor, partially apart with a 12 hp briggs and Stratton engine. motor actually runs good. It has a starter generator, regulator, and solenoid but no wiring, it was taken off before I received it. I have a new 5 tab ignition switch with B,A,R,S,and I marked on back side. Does anyone have any info as to rewiring this tractor, any and all help would be greatly appreciated. deans
   / Allis chalmers HB112 wiring help #2
b=battery, a=accessory, s=starter I= ignition not sure about "r". The regulator will have letter marks as will the starter/gen. The briggs engine will have a "kill" wire that is grounded to shut down the engine. It will have a built in mag so does not need power to run. If you can find a wiring diagram from any tractor using a briggs or kohler and a starter/generator it will be the same or close. Cub cadet comes to mind and might be easier to find a diagram for.
Miller Spectrum 500 DC Plasma Cutting System (A54811)
Miller Spectrum...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
2015 Ford F250 Ext. Cab 4x4 Flatbed Truck (A53422)
2015 Ford F250...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A53473)
2012 NEW HOLLAND...
