Allis Chalmers H3 steering clutch
   / Allis Chalmers H3 steering clutch #1
Morleys
Poplar, WI
AC H3
My AC H3 crawler stopped driving on the right side over about a 1 hour period of time while I was grading. It would only go in a circle to the right. I pulled the clutch from the right final drive housing which had a lot of water and grease in it. All of the teeth on the driving discs (fiber) were gone and the hub is not tight (has wobble when wiggled). Is this just a pilot bearing gone bad, or do I have other problems that would cause it to stop driving on the right side? I must have a worn seal on the drive shaft too with all the grease in the housing. I will replace the drive shaft bearings/seal, the pilot bearing on the clutch and the fiber discs. Anything else? Thanks
2019 FORD F-550 SERVICE TRUCK (A53843)
2019 FORD F-550...
2015 Tiger Trailers Inc. Gooseneck T/A Enclosed Trailer (A51692)
2015 Tiger...
MISC BASKET OF HYDRAULIC PARTS (A53843)
MISC BASKET OF...
2012 Ford Crown Victoria Sedan (A51694)
2012 Ford Crown...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
2010 Toro ReelMaster Pull-Behind Hydraulic Reel Mower (A51691)
2010 Toro...
