dcwatson84
- Joined
- Jan 6, 2011
- Messages
- 35
- Tractor
- Allis Chalmers B
Ive got a 49' Allis model B. Ive had it for about a year and a half. Before I bought it someone retrofitted it with a rear hydraulic lift that uses an old power steering pump for pressure.
Before starting the garden this year I decided to overhaul the hydraulic system to see if I could correct some problems ive had with it. I replaced all the hoses and fittings, and drained/refilled the pump. I installed a pressure gauge between the pump and 4way valve. I also wanted to try out a new hydraulic cylinder, unfortunately the only new one I had was a 2 inch, the old was 2.5 inch.
And now the rear lift wont even lift my 1 bottom plow. My first assumption is that the only real change is the 2in vs 2.5in, but in reality, a change of that magnitude (2.5 to 2 inch) shouldn't affect the ability of the system to lift a little single bottom plow?
So to the real issue I guess - the new pressure gauge reports that the pump is only producing slightly less than 100 psi. That seems to be *extremely* low. I guess I was lucky to ever be lifting the plow in the first place?? Has my pump gone bad?
When the pump stroke stops and refuses to lift, I see that the pulley locks up. I tried tightening the belt but that doesn't seem to help, the pulley still locks up at the same spot. So if its not a belt issue, what are some other things that could cause this pump to produce such low pressures? I checked over and over for air bubbles and although there were a few after the drain/refill, I think the air has been purged.
Edit:
This just came to mind... Is it possible that I crossed up the pumps in/out hoses? And that the pressure is low because the only pressure in the line is the pumps intake (which would be much lower i think) and not the actual pressure produced by the pump motor? Or would that even work at all? I guess I can always switch the location of the gauge when I get home this evening and double check, but any other suggestions would be appreciated as well!
Edit:
