Allis Chalmers 5015
   / Allis Chalmers 5015 #1
tgreen0425
Hey folks, I bought a little AC5015 last year to use around my home. I have about 4 acres and it is perfect for my needs. It is getting time for some service and I understand fluid levels and such but my problem is parts. Since AC is no longer in business where would a I find an air filter for it? Can anyone give me a part name and number that will work? Any help would be appreciated.
Tim
   / Allis Chalmers 5015 #3
These are rugged tractors for their size. Mine is a 1983 with 18 HP Toyosha engine. I plow, brush hog, grade and do other miscellaneous landscaping with mine. This tractor will start no problem with just glow plugs in below zero temperatures without an engine heater. Amazing. Runs fine on biodiesel and regular diesel. I double down with power serve in the winter just as a precaution.
NAPA Online also has a lot of common service parts and filters. You can search by make and model. Sometimes you'll have to do some digging and cross referencing though. Example is the fuel filter 3282. FIL 1210 hydraulic;
FRAM PH4386 oil; FIL 3282 Fuel Filter.
Go to http://www.agcopartsbooks.com/EpsilonWeb/login.aspx?region=NorthAmerica[/URL] and you can look up all the parts that you'll need. My local Massey Ferguson dealer can get many common parts. Prices are normal retail for a dealership; sometimes expensive.
I have the owner's and parts manual that I downloaded for free from the Simplicity website under model 9518 in PDF format but they are too large to attach to TBN posts. 9.55 MB zipped.
I've been using amsoil SAE 30/10-30 synthetic in my 5015 because it can be used all year especially in New England winters. No need to go to 10 weight or 20-20W as indicated in owner's manual. AMSOIL - Synthetic 10W-30/SAE 30 Heavy Duty Diesel Oil (ACD)
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A50854)
2018 WACKER NEUSON...
2019 CATERPILLAR D6N LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2015 PETERBILT 367 HOT OIL (A50854)
2015 PETERBILT 367...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
