All Wheel Steer
   / All Wheel Steer #1
jaydee325
Veteran Member
Casco, Mi
John Deere X584 Garden Tractor & LS R3039H
I'm thinking about retiring my trusty John Deere 325 garden tractor after 23 years of great service. So, just starting the research into a new tractor.
The All Wheel Steer models in the X5XX range are interesting and appear to be quite handy. I'm concerned with the added complexity of such a system.
I'd like to hear from those of you who own a Deere AWS tractor. Please share the good or bad!
   / All Wheel Steer #2
I had test driven the Deere AWS tractors because I loved my supersteer TC33D tractor. I ended up buying a x744 AWS and it is mostly my wifes tractor because she LIKES mowing and does it on her own. I would say it was worth buying....wouldn't you? My dad needed something to mow/plow his property too. He has many obstacles to mow around and needs maneuverability when plowing around his garage. He bought a x749 AWS. I did trade the TC33D in on my toolcat and it is also a AWS vehicle. Can you guess that I like equipment that turns sharply? I have NEVER had a issue with the AWS on any of the units and NO, they are not even getting loose or sloppy.
   / All Wheel Steer #3
Have had at least one (now three) AWS for last 25 years..would NOT be without it. Never one problem with the linkage. Very robust.
Sidehills are easier to negotiate, turn-arounds quicker, backing up equipment easier, seeking better traction easier, steering front mounts (blade, broom, blower) easier, parking easier, and the list can go on.
   / All Wheel Steer #4
I have a 2016 X584 and I love it. I have many serpentine edges and trees to mow along, and the maneuverability of the AWS makes this very easy. Power steering with a spinner on the steering wheel makes all the turning a breeze. I considered zero-turn units for my mowing, but I needed the tractor for pulling a dump cart and other utility tasks.
I have the 54" Accel deck on it and it cuts very well. No concerns or issues from me regarding any of the hardware needed for the AWS.
If you need both maneuverability and utility in a lawn tractor, then the AWS units are a good tool for the job. Highly recommend.
   / All Wheel Steer #5
I have a JD x485 AWS. I would buy AWS again. Over 600 hours and still tight steering. I am guessing the rod ends will last 1000 hours.
   / All Wheel Steer #6
Do any of you AWS'ers install tire chains in the winter for a plow or snowblower?
Any problems with chains rubbing when turning?
On my non-AWS, I have to be careful to not leave too many links dangling on the inside so they don't snag on bolt heads.
   / All Wheel Steer #7
Coby
Cut the chains so they fit the tires and leave NO links dangling on the inside. just sayin....
   / All Wheel Steer #8
I love my AWS 455 , the only disadvantage I can think of is I have trouble plowing or mowing right up against a fence in a long straight line just because as you steer the front away from the fence the rear moves closer. That being said, I’ve never hit anything but I didnt expect that the first time I was using it.
   / All Wheel Steer #9
No tire chains needed here in Texas. Maybe for mud, but not for snow. :)
   / All Wheel Steer
All,
Thanks for the input.
Good point on chains as I will want to use a snowblower on any machine I get. I'll be sure and ask that question when I get to a dealer to look.
2006 John Deere 650J LGP Crawler Tractor Dozer (A50322)
2006 John Deere...
UNUSED CFG Industrial QK18R Mini Excavator (A47384)
UNUSED CFG...
2003 John Deere 270 Series II Compact Wheel Loader Skid Steer (A50322)
2003 John Deere...
2017 CHEVROLET SILVERADO CREW CAB TRUCK (A51243)
2017 CHEVROLET...
Truck Bed (A50774)
Truck Bed (A50774)
2005 Mack Vision Semi Truck (NOT RUNNING) (A50774)
2005 Mack Vision...
