all the different classifications
   / all the different classifications #1
retiredmgn
I posted this on the JD forum, that's what my tractor is. Perhaps this is the proper forum.
Hi folks,
I went shopping today to pick up engine oil for 50 hour change. Dang. Changed my share of oil but this time I wanted to 'do it by the book'.
Never payed attention to much more than viscosity but the JD manual lists several specifications from the manual as follows -
John Deere Plus-50 is recommended (thanks anyways but JD oil is pricey)
ACEA Specification E4/E5 may be used (couldn't find this spec on any oil)
Other oils may be used if the meet one or more of the following:
API Service Classification C1-4 (nope)
API Service Classification CH4 (nope again)
ACEA Specification E3 (scarcer than hens teeth)
To top it all off I came across oils that were labled "Diesel" (but without said specs) and others listed "for gasoline".
The chart in the manual shows I should use SAE 5W-30.
Sooooo, what do you guys use??
Have made the change in my manual.
Thanks for the info.:thumbsup:
   / all the different classifications #3
CI-4 is still readily available....
CJ is an updated oil that has significantly lower ash/phosphorus..
   / all the different classifications #4
I use Mobil 1 0w30 in my 4010. It's mainly for gasoline but also light diesel. Change once/year with generally less than 100 hours on the oil.
Ralph
   / all the different classifications #5
I think I'm going to try John Deere's 0w-40 synthetic. I'd like an 0w-40 for both my dump truck and the tractor, and I think its still CH rated (higher ZDDP??). I wonder who makes it though...
2012 Ram 3500 Crew Cab Flat Bed Truck (A53422)
2012 Ram 3500 Crew...
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
2017 Mitsubishi Mirage G4 Sedan (A53424)
2017 Mitsubishi...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2015 FREIGHTLINER...
