All Aluminum Trailer CargoMaxxx
   / All Aluminum Trailer CargoMaxxx #1
TimP
Platinum Member
Kingsville, MD
B3000HSDCC
Has anyone ever seen one of these in person ?
2013 Cargomaxxx 6 5'x16' Aluminum Utility Trailer Spring BLOWOUT Price | eBay
This seller has been selling them on ebay for a while and I have been tempted.
The price is fairly comparable to a regular metal trailer.
I do worry about repairs if the deck ever gets damaged. At least with the steel trailer with wood decks you can throw on a new board, but with aluminum it would not be an easy fix.
The price of these does keep creeping up and up and I woul dhave to take a 12 hours round trip drive to Pittsburgh area to pick it up.
Thanks.
   / All Aluminum Trailer CargoMaxxx #2
Ummm i think that trailer is located in clarion pa, thats two hours north of pittsburgh. Up by interstate 80. I dont know if that is closer to you or not.
RedNeckRacin,
Thanks for the info. I'm on Baltimore so that would put it a little further away.
   / All Aluminum Trailer CargoMaxxx #4
Aluminum trailers do have their own issues.
I have worked on aluminum semi trailers and suspension connection problems seem to be common. Steel fasteners in Alum need special consideration to prevent electrolesis.
While steel will tend to bend, Alum has more problems with cracking and breaking.
You do realize that unless you keep it in a vaccuum chamber and never use it, it won't stay that shinny?
You can probably buy two steel trailers for that price too.
I have a simular 6.5 X 16' steel trailer and have scaled it and it only weights 2-300 more lbs than they are stating.
QUOTE]
Stimw, Ya.... I was thinking the same thing about the cost.
Maybe I should start scanning the local area for a decent used trailer.
I'm thinking I could pick one up for around $1500-1800.
Thanks !
   / All Aluminum Trailer CargoMaxxx #6
You can buy a new 16' trailer for that.
Chris
Thanks Diamondpilot.
I have to start shopping around......
   / All Aluminum Trailer CargoMaxxx #8
The last person to post a AL trailer.... I pointed out i think they spent almost twice as much for the AL one vs a steel one for 600lbs of additional carrying capacity.
If you ask me they are the worst buy going in trailers.
schmism,
True.... the load capacity is not much different. Perhaps not worth any extra money.
   / All Aluminum Trailer CargoMaxxx #10
schmism,
Yea, my 18' by 82" wide 7000# trailer is only 1500# with the spare, winch, and strap/chain box full. Its steel.
Chris
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
MOBILE OFFICE CONTAINER (A53843)
MOBILE OFFICE...
2008 New Holland B110 MFWD Loader Backhoe (A53473)
2008 New Holland...
2024 KMC 7406 (A53084)
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
