Alge Stains on Roof shingles
   / Alge Stains on Roof shingles #1
beersngars
Ohio
Kubota L3400HSD
Thought I would ask fellow TBNer's if anyone has first hand experience removing the alge stains from roof shingles. I have read many different recipes on how to get them clean. Some say TSP and clorine bleach in anywhere from a 50/50 mix to 25/75 (bleach and water) and a few spoons of TSP per gallon to a cup. Others say forget clorine bleach and use oxygen type bleach such as OxyClean and water. Of course there are premixed solutions with all kinds of claims, but most seem rather expensive. I have a backpack sprayer and will do the job myself.
   / Alge Stains on Roof shingles #2
About any of the solutions will kill the algae. Some water with bleach will work, but if it is a layer that has some thickness to it, may take longer than you want to wait.
Might apply it and then hose it off clean, figuring the solution will break the connection to the shingles.
For long term prevention, a ridge cap of some galvanized metal or copper will keep the algae from forming in the first place.
   / Alge Stains on Roof shingles #3
on my vinyl siding about once a year, i use a 50/50 mix of bleach/water in a garden sprayer. let sit a few minutes and blast it with the garden hose w/ a pressure nozzle. should work ok on asphalt shingles.
   / Alge Stains on Roof shingles #4
lowes sells a jug of stuff with hand pump sprayer that is for asphalt shingles, vinyl siding and painted stucco and concrete for removing algea stains.
soundguy
   / Alge Stains on Roof shingles #5
ive had success with liquid algaecide for pools sprayed on and left for a while and hosed off ... keeping trees a distance from the house helps with circulation and will help keep the roof dry and limit regrowth too
   / Alge Stains on Roof shingles #6
I recommend "Wet and Forget". Used it this summer and it works great. Just spray it on your roof and you're done. Requires no scrubbing or rinsing. You can get 1 gallon at amazon.com for $27 plus $10 shipping. 1 gallon makes 6 gallons of ready to use product, which will cover approximately 2000 square feet.
   / Alge Stains on Roof shingles #7
Will galvanized leaching kill Alage? I know my aunt and uncle had streaks on their roof and they came out cleaned the roof and put a cap of galvanized metal on the roof.. No more streaks.
Wedge
   / Alge Stains on Roof shingles #8
You can, but bleach in the Chlorox bottle is much, much cheaper. :)
The only reason to rinse is to get rid of the dead algae after the bleach kills it.
   / Alge Stains on Roof shingles #9
Wedge
interesting that you mention that.
I have a concrete drive that gets the normal black algea on it in the pores of the concrete.. except about a 3' area around a gat that sets over the drive. it's it brite zinc plated... concrete is completely clean under it and in it's drip line and an area about 1.5' on either side of it.
does make ya think don't it.
I had heard copper killed some stuff.. and silver too...
soundguy
   / Alge Stains on Roof shingles #10
For additional proof of the galvanized metal, look at about any barn roof that has a galvanized cupola on it, and see the clean streaks on the shingles below that cupola.
Some people, that put natural wood siding on their homes, will place a copper wire just under the lower edge of a row of shingles (or siding) that will keep the mildew off the siding for many years.
Utility Trailer (A52377)
Utility Trailer...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A54607)
2013 KENWORTH T680...
KMC 5610 (A53084)
KMC 5610 (A53084)
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2014 Ram 1500 4x4...
Test Button (A47477)
