Algae in a Bunch of Diesel - Opinions Wanted
   / Algae in a Bunch of Diesel - Opinions Wanted #1
RDrancher
Veteran Member
North Texas
New Holland
First, to be clear I know it's not really an algae, but that's what everyone calls it so that's what I'll use to describe the problem.
The background story is that I purchased a dump truck with full fuel tanks that developed filter clogging issues right off the bat. I figured it might be algae related so I treated with a biocide. It started going through filters, coughing and cutting out like crazy. Peering into the tanks with a flashlight I could actually see the black junk on the walls of both tanks, one much worse than the other. We pumped both tanks into transfer tanks I had on hand and used a brush and anything else we could get through the filler to clean the best tank. We replaced all of the fuel lines / filters and cleaned out all hard lines including the egr cooler plate. We did not connect anything back to the really bad tank. The truck has been running fine since.
My problem now is having a 30 gallon and 110 gallon tank full of treated but contaminated fuel. Since we're talking 140 gallons of fuel it's not like I can just dump it, so I would like to filter the fuel and reuse it and also be able to put the transfer tanks back into service. Both tanks have been sitting undisturbed for several weeks. My idea is to pump the tanks out a little at a time while keeping the pickup well off the bottom to avoid sucking up any junk. The fuel will be pumped through a standard transfer tank filter and also a clear-cased water separator/filter so I can visually monitor it.
Am I on the right track here?
Once they're fairly empty I'm pretty sure I can clean out the bottom of the tanks, even if I have to use a pressure washer and let 'em bake in the Texas heat.
   / Algae in a Bunch of Diesel - Opinions Wanted #2
. . . We did not connect anything back to the really bad tank. The truck has been running fine since.
I think you are on the right track. The fact that the truck has been running fine endorses your procedure.
I would suggest de-mounting and cleaning the really bad tank as soon as practicable. If it will be a while put some fuel in it and roll it periodically to keep the insides wetted; I suspect that if that black stuff dries and bakes on/into the insides of the tank it will be very difficult to clean.
Gravity is on your side as far as separating the bottoms, sediment, and water. After emptying and re-cleaning one of your transfer tanks you could use that as a settling tank for the material in the other transfer tank. Time is not on your side if the contamination is organic. Therefore I would use the decanted fuel quickly as I could.
   / Algae in a Bunch of Diesel - Opinions Wanted #3
Watch out for water in the fuel. It is a product of the biologic consumption of hydrocarbons.
   / Algae in a Bunch of Diesel - Opinions Wanted #4
There are fire stations around here that accept hazardous waste, including fuels. Whenever I drain a tank and don't want to reuse the fuel I take it there. Not sure if they have that in your area.
   / Algae in a Bunch of Diesel - Opinions Wanted #5
The same here. Just call or stop by you local fire station and they'll tell you where to get rid of it.
Our county landfill also has 2, no-cost, Haz. Waste drop-off days per year and you can bring a certain number of gallons of fuel to be properly recycled.
DEWFPO
   / Algae in a Bunch of Diesel - Opinions Wanted #6
Sounds ok just add Power Services Storage "snake oil" when you fill up your clean tank(s). It prevents such from occurring......does for me in Texan heat, anyway. Wink!
   / Algae in a Bunch of Diesel - Opinions Wanted #7
Old diesel or gas makes a real good weed/vegetation killer. As long as you spray it and not dump gallons in the soil, it's mainly an air pollution thing... Diesel is good for parts cleaning and starting piles of brush on fire... And you can always use it to burn krap like we did in Nam. Once you get your tanks cleaned up I would think twice about trying to filter the old diesel and put it back in.
2021 CATERPILLAR 262D3 SKID STEER (A52705)
2021 CATERPILLAR...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
2024 VOLVO VNL760 SLEEPER TRUCK (A54607)
2024 VOLVO VNL760...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
WACKER NEUSON EZ36 EXCAVATOR (A52705)
WACKER NEUSON EZ36...
2015 Ford F450 Flatbed Truck (A52377)
2015 Ford F450...
