Airing down tires
   / Airing down tires #1
Dougw133
Bronze Member
North Eastern PA
Hi, Have a Mahindra 5035 HST. Got it about 2 months ago. Now that the weather in the northeast finally seems something like spring I am getting out and getting projects done. I have the R4 industrial tires. It some areas I leave some chunks and ruts where it seems it's not a swamp but maybe slightly more saturated. I am to use this for pulling a 7 Foot Rear Finish Mower. Today I used the FEL to rip up sod for an area of garden. The 4 or 5 trips in the same spot into where I was working left 6 inch deep ruts. Not muddy, but ruts.
I got a suggestion to let some air out of the tires. Anyone have any advice as to how much? How much will this actually help?
Thank you
   / Airing down tires #2
Maybe de-airing tires would work, but I don't think I would do it. I would hate to take a little to much out and run one off the rim because I worked it a little to hard.
   / Airing down tires #3
One measurement I remember from long ago for soft sand was to let air out until sidewall height was not less then 2/3 of normal height. That probably won't be as universal now with some tires being of a wider cross section.
Bruce
   / Airing down tires #4
Of course making the surface area of the tire larger (via deflation) would give you some additional floatation. But I doubt it would be enough to make much of a difference, especially doing loader work. The front tires already have a smaller footprint, but then you add the weight from the FEL and you'd have to be careful to not break the bead.
   / Airing down tires #5
i agree.. I'd be a lil leary of underinflating a tubless... fine line between usefull extra traction, and running it off the rim in a turn with a lil side force from rutted mud or debris on a sidewall..
   / Airing down tires
Thanks for the replies. Perhaps removing the Fel for mowing would help..?
   / Airing down tires #7
That's a 2 and 1/2 ton tractor, any weight you can remove for yard work will probably help.
   / Airing down tires #8
A lot depends on just how much air is in the rear tires now. Mine was delivered with far too much air. The tires said NOT to inflate over so many pounds while mounting. THAT is the pressure they were delivered with.
In my younger days I used to run large radial tubeless tires on my 4x4. They were rated to carry 2500lbs each, at 45psi. I ran them hard on a 4000lb truck, at 10psi with no problem. At 8psi they started to "look soft" when on a hard surface, but at 10-12psi they ran fine on pavement or mud, as long as I kept speeds below 65mph. (sacrificed a few mpg)
   / Airing down tires #9
First check to make sure they are not over inflated. After that; airing down would help, but I would only do it with the FEL removed. Removing the FEL would defiantly be the thing to do for mowing.
   / Airing down tires #10
Check your tire pressure, I suspect that they came with max air in them to make them ride better during transit and not bounce. My LS had over 20 PSI in the rear. I reduced it to 12 and I think it is still a bit high for max traction. Normal rear pressures is 8-12 depending on what load carrying you are doing and if you have maxed out rear wheel weights etc. Since most CUTs dont come with wheel weights, you would likely be good with 8-10 PSI. With FEL you need to keep them aired up more so than the rears due to the turning forces with a full load if not properly inflated, you could roll one off the rim.
On the rear, you should see a bit of a bulge in the sidewalls and full tread marks on dry pavement.
Electric Mobility Scooter (A51694)
Electric Mobility...
Kivel 48'' pallet fork attachment, 3500# capacity (A53421)
Kivel 48'' pallet...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
Backhoe Bucket (A53117)
Backhoe Bucket...
2015 INTERNATIONAL LF687 (A53843)
2015 INTERNATIONAL...
2009 Lexus RX 350 SUV (A53424)
2009 Lexus RX 350...
