Airbag (SRS) Light on Dash. Easy Fix
   / Airbag (SRS) Light on Dash. Easy Fix #1
zzvyb6
Super Member
michigan
jd 1070
My airbag (SRS) light has been on for a few months. Dealer scoped it and his scanner up came B1811 SRS Code replace ECU. $1200 for the part alone, no oem anymore, need aftermarket. Ok, so I bought an Actron OBD reader finally for another vehicle's issue. Next was to read the airbag car with my reader. Same code, but with a database in it showing most likely cause: Shorted Clock-Spring in steering column. New OEM part $80, new aftermarket part $40. I caved and got the OEM part. Watched a few youtubes on how to make the change and in 15 minutes my 'clock spring' was replaced and my airbag light was off.
I took the old 'clock spring' apart (its a ribbon wire wound around a set of rollers. Yep. there was a wear bar all the way through the ribbon insulation, so, probable cause. As easy and low cost as this was, there should be no hesitation to take care of this problem in your cars if this is the case. You need the airbags as well as you need seat belts these days.
   / Airbag (SRS) Light on Dash. Easy Fix #2
I can just about guarantee the dealer knew what the problem was. I think he was just hungry. You didn't mention the year and make but that clock spring has been a weak link for years--Many years. I changed out a few myself. The Actron OBD readers are pretty good. I still use my old CP9190. :thumbsup:
Glad you didn't set the air bag off. :eek: No more than a static electricity discharge and they can knock you out when they explode. I always wore a grounding wrist band when working around them.
   / Airbag (SRS) Light on Dash. Easy Fix #3
I've got a CP9125 and it's good for what it is. Unfortunately it doesn't recognize my wife's (2015) car, I contacted them about updating it but they never replied. I suppose I should give them one more chance.
Don't need one often enough to have to buy a new one every time the automakers change something, you'd think these things could be easily updated.
   / Airbag (SRS) Light on Dash. Easy Fix #4
Just be glad it isn't a BMW. None of the code readers will scan the BMW SRS system and the old scan software that does only runs on Windows XP. I broke down and bought the interface and configured and old laptop with XP to try and figure out our 2003 Z4 SRS light. Still not sure what the problem is. I get different translations on what the code is and means with it and it's not worth thousands of dollars to fix a $5000 car.
We Don't Dial 911 Wall Art (A55853)
We Don't Dial 911...
LG TROMM STEAM WASHER WASHING MACHINE (A57192)
LG TROMM STEAM...
JOHN DEERE 6000 SERIES BRUSHGUARD (A57192)
JOHN DEERE 6000...
40" EXCAVATOR HYD TILT BUCKET (A57192)
40" EXCAVATOR HYD...
2018 Altec DC1317 Towable Brush Chipper (A55851)
2018 Altec DC1317...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
