Air seat for M7060 fat guy
   / Air seat for M7060 fat guy #1
RoyKing
Platinum Member
Gainesville Florida
M7060HSC/18, RTV-X1100C
Worked with Nick at Toughseats.com they built me a Custom Grammer model Air seat. I will have make adapter for the different bolt pattern to mount it but the M7060 just has flat plate with 4 bolts over the AC.
Model MSG97HD/741 in 12vdc, with right armrest only, cloth black, rated 440lbs, has fore/aft/tilt for seat base, short back no headrest. Also has the largest seat width. The last two numbers in 741 tells you seat width 4 widest 2 narrow, 1 is low back 2 is nigh back.
Tough seats is full service shop you can't buy sight that direct, they have all the parts and assemble to your need. Was not cheap. $95 s&h
Can't post pic because there is none in the catalog configured that way
   / Air seat for M7060 fat guy #2
There have been lots of people over the years asking where they could get air ride seats from. Pretty relevant with a good source.
Seat arrived already ordered 25th arrived 28th. Grammar seat quality exceeds my expectations. Figured that it would be about the same as the Grammer that came with the machine... WRONG. Much nicer from the cloth, foam density, heavier frame. Nothing wrong with the one that came on my m7060cab, rate it as good.
So anybody wanting a great seat and service talk with Nick at ToughSeats.com, go to Grammer web site look for features you want and they will build it for you
Finish the seat installed today huge improvement over factory. An adapter was needed used two 1 x 3 x 0.120 x 17" pieces of tubing drilled 4 holes for the old 10 x 15 pattern, and then four more for the new 15 x 15" pattern. Shorted out the occupied seat switch with jumper plugged into harness, order the m9205 wiring harness and change the seat plug. With seat depth at max and seat at full rear, sitting nice and high for great visibility and easy access to the accelerator.
Hyster H225E (A47384)
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2017 FREIGHTLINER...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
2010 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52576)
2010 PETERBILT 387...
2013 PETERBILT 388 (A52472)
2013 PETERBILT 388...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
