Tires Air pressure
   / Air pressure #1
mguitas
Super Member
Schuylkill County Pennsylvania
Massey Ferguson 1423 Hydrostat
I was reading some past posts about air pressure for FEL work. I'm going to set my front tires for 35 PSI. What would you set your back tires for 12 16.5 NHS max air pressure 40 PSI. Just like to see what you guys are running your back tires at. I think my back tires are at 25 PSI now. Thanks.
   / Air pressure #2
I have a MF235 with a FEL, I keep 30 psi in front tires and have my rear tires full of 1/2 water - 1/2 antifreeze mix, filled to up over the top of the rim, when they are upright.
I keep 25 psi in the rear tires, but be sure to have the valve stems at the top when you check the pressure or add pressure.
Hope this helps!
Ray
UNUSED JCT SKID STEER QUICK ATTACH CONCRETE MIXER (A51244)
UNUSED JCT SKID...
UNUSED FUTURE MINI EXCAVATOR ATTACHMENT SET (A51244)
UNUSED FUTURE MINI...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
2010 Astec Underground RT660 4WD Trencher (A50322)
2010 Astec...
2012 GMC SIERRA SLE CREW CAB TRUCK (A51243)
2012 GMC SIERRA...
2019 JOHN DEERE XUV855M GATOR (A51243)
2019 JOHN DEERE...
