Air in Fuel Line
   / Air in Fuel Line #1
gar2376
Kansas City
I have a JD F935 front mount diesel mower and am having a problem which I think is caused by air getting into my fuel line. It will run fine for awhile, but then it starts wanting to stall out. If I open up the bleeder screw and turn on the key so the fuel pump starts to pump, I can see little spurts of air bleeding out of the bleeder screw. After a few minutes straight fuel is coming out of the screw (no air) and I can tighten it back up and it will start up and run fine for a few minutes. Once I engage the PTO and hit thick grass, the process starts again. I thought maybe I had a pinhole in one of the fuel hoses. I have replaced all hoses and the problem still exists.
One thing I don't quite understand though, is that I don't believe I have a fuel/water separator. Is this optional?? My system appears to go from fuel tanks -->in-line fuel filter-->fuel pump-->fuel injection pump. I have a dual tank setup, and the attached pdf shows it should go fuel tanks -->fuel pump-->fuel/water separator-->fuel injection pump. On the single tank version of the attached pdf, the fuel/water separator looks just like the shape of an in-line fuel filter. According to the attached schematic, there is no in-line fuel filter before the fuel pump. Am I safe just taking this out? Do I need to get a fuel/water separator? My model does not have the water-in-fuel indicator, but I wouldn't think this would mean I don't need the separator.
Any help would be appreciated.
  • John Deere F911.pdf
   / Air in Fuel Line #2
It sounds like it may be a venting issue. Some have external vent lines and some have a vented fuel cap. Try loosening the cap when it starts to stall and/or listen for a big "whoooosh" of air entering the tank as the cap is loosened.
2025 JOHN DEERE X350 LOT IDENTIFIER 153 (A53084)
2025 JOHN DEERE...
6" & 8" I BEAMS UP TO 16' LONG (A51247)
6" & 8" I BEAMS UP...
2023 UNVERFERTH 632 LOT IDENTIFIER 166 (A53084)
2023 UNVERFERTH...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
28013 (A50322)
28013 (A50322)
UNUSED HURRICANE GALVANIZED METAL LIVESTOCK SHED (A51248)
UNUSED HURRICANE...
