Air filter
   / Air filter #1
RobertBrown
Veteran Member
Florida
Bolens G192/TS1910 Ford/New Holland 1920
Does any one where I can get an air filter for a Bolens G192/Iseki 1910, without spending a fortune, It must cross over to an easily obtainable cartrige somehow.
Thanks for the help
   / Air filter #2
Hey Robert,
I believe that the 1910 is like the 1610TS. I had the same problem with the air filter and talked to some folks at Wix Corporation and we determined that the napa 6270 will work. It is about 2/3in. shorter. All you have to do is knock out the brace which is inside of the cylinder. You need to cut off a couple of inches and weld it back together. Then it should work like a charm! That air filter is about $15 I believe instead of the $80 like the other. Thanks, talk to you soon. Hope this helps. Rambo, NC
   / Air filter #3
I use a WIX 46326 in The 1610s. You might check that one out also.
   / Air filter
I measured the filter that came out of the tractor and visited the Wix website and preliminary indications are that the 46326 is close enough. I suppose the plastic fins that create the vortex are not really critical to proper performance. I will try to get one(42636) and let you guys know if it fits. Thanks a lot, I really appreciate the help. If it works it will save me a bunch of time, headaches and money.
   / Air filter
Thanks Rambo
If the 46326 doesn't work I'll try the NAPA route. They just quoted me 35.00$ for the wix(46326) filter.
   / Air filter #7
FYI Wix and NAPA are the same ,you just drop the first number.
   / Air filter
how much are you paying for the wix filter, and where do you get them?
   / Air filter #9
I am doing some work at the shop today, so I'll check and get back.
   / Air filter #10
I checked today. The NAPA filter lists for $51 and my dealer cost is $35 and change.
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
2020 KUBOTA RTV...
2018 Ford Escape SUV (A50324)
2018 Ford Escape...
