Air filter warning light
   / Air filter warning light #1
orb
Bronze Member
Rock Hall, MD
Farmall H, Massey Harris Ferguson 50 w/300 loader, Kubota 3010
About 2 months ago the air filter warning light appeared on my 3010 with 65 hours on the meter. I found it hard to believe that the filter was the problem since I just had the 50 hr service with the air filter changed at the dealer about a month prior. Sure enough when I opened the front and took out the filter it was clean as a whistle. I removed the grass and junk that had accumulated on the radiator screen and I wiped off the little contacts I saw in the inside of the air cleaner housing. The light stayed on. My initial call to the dealership was rather disappointing. At first they said it wasn't under warranty because the tractor was two years old. Then they said it was probably just a bad light bulb. I must have told the guy ten times that the problem was that it wouldn’t go off, not that it wouldn't light up! Anyway, long story short, I finally found someone at the dealership who seemed like he knew what he was talking about. At first he wanted me to bring the tractor in for repair, 50 miles there and 50 miles back for a malfunctioning censor. I told him no way was that going to happen.
Well the part came in last week and I drove to pick it up. Replaced the censor last night and no more warning light. I still need to mail the old one back to him, but finally I can stop looking at the orange glow coming from my dash.
Oh, by the way I spoke to a mechanic at the dealership (wanted to make sure there were no tricks to replacing the thing) and he said this was a common problem on the 3010. Apparently the factory had a lot of these bad censors at one time.
   / Air filter warning light #2
Good information. I did not even know there was an air filter sensor!
   / Air filter warning light #3
Funny, mine lit up after the first few hours or so when I brought revs up to PTO speed. The filter was clean, etc., so I figured I'd look into it when I got the time. Eventually, the problem just went away.
Self healing system, I reckon.
   / Air filter warning light #4
What a coincidence, on Sat 6/28 my air filter light came on and wouldn't go off after I blew out the filter... I replaced both the inner and the outer filters today and the clogged filter light stayed on. I've pulled the sensor and will pick up a new one tomorrow if the dealer has one in stock. My L3710 is 4 yrs old with 400 hrs, I hope this is a cheap sensor. It looks like $2 worth of plastic and wires, probably closer to $20. This will be the first repair in 400 hours and 4 years, so I really cannot complain.
   / Air filter warning light #5
Did it work for you?I replaced mine and it worked for a few days and now its not working
2009 INTERNATIONAL PRO STAR (A52472)
2009 INTERNATIONAL...
CFG Industrial Q.A Auger (A50121)
CFG Industrial Q.A...
7'x16' Utility Trailer (A50121)
7'x16' Utility...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
Towable Orchard Sprayer (A51691)
Towable Orchard...
