Air Filter for SL 3105 engine
   / Air Filter for SL 3105 engine #1
Hickory Creek
Bronze Member
Desota Forest, ms.
WT404
Can someone provide me with the air filter number for the Worktrac(Foton) 404 with the SL 3105 engine, so Napa can cross it. Original filter has no numbers on it. If you have the oil filter number too, that would help.
Also, is there a page on this site where one can post common used part numbers for different name tractors. I know some same model number tractors used two different engines from what I have read. It would be nice for new people and also for others to post part numbers of specific model and engine tractors to help others.
Thank you in advance.
   / Air Filter for SL 3105 engine #2
I have a 2005 foton 404 3 cylinder. It came with the metric threaded oil filter. If yours is metric threaded unscrew the stem and take it to a machine ship and get a 3/4 thread from a good parts store and let them cut and weld the 3/4 stem on to the metric stem. then you can use common filters like the wix 51515 or FL1A. Or you can order filters for about $20 each from one of the suppliers.
The air filter is cleanable and reuseable for 600 hours according to the manuel. I didnt do that I bought a similiar sized paper and foam made filter at autozone that was made for a ford car.. I replace when I change engine oil. I dont remember the filter number but it is easy to find one with close dimensions. I had to drill a dole for the bolt to go on to hold it in place the way the original does.
this is what I did theres a lot of people that would not do any of this.
You decide.
Thanks, wnet to Autozone yesterday and saw a filter that was close to size, and as you said, no hole for through bolt. Quick question, did you leave the plastic vane in canister. I assume it acts as a vortex generator or something like that? Was concerned about light weight screen on filter not holding up under load.
   / Air Filter for SL 3105 engine #4
1995 Stoughton Enclosed Dry Van Trailer, VIN # 1DW1A5323SS900663 (A57453)
1995 Stoughton...
Kubota BX25D (A53317)
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
Jet Ski (A59231)
Jet Ski (A59231)
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
