Hard to say for me how Yanmar is doing, but my experience with Lombardini air cooled diesels is excellent.
You have to notice some differences, ositive and negative to both type:
1. Diesel is louder, and cause more vibrations, particularly single cylinder, compared to gas.
2. Diesel has bigger torque, especially in bottom rpm - better for pulling and pto work which don't need full pto speed (like tilling).
3. Diesel use less fuel per hp, compared to gas, and fuel is cheaper (non road diesel).
4. Diesel engine is heavier in same hp class, so, it will give you a better weight balance when we talk about walkbehind machines.
5. Diesel engine will last longer, as it is heavier built than apropriate gas, and ALL diesels have oil pump, compare to simple gas, which usually have splash lubricating.
6. Diesel engine is better for work on slopes, means non sensitive to "carb level".
7. According to my knowledge, Yanmar and Lombardini are direct injectin diesels, so, starting in winter will not cause a problem, even in winter. Especially if machine is stored in barn
8. Air cooled diesels (for walkbehinds) are simple built, like a gas - no radiator, no water pump etc, so maintenance is not a issue.
9. Diesels are hard workers, and are less sensitive for overheating, compare to gas engines on partial rpm.
10. Diesels are MORE EXPENSIVE /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif compare to gas engines (almost twice in same power class, Lombardini in my country)
Lok for a thread about
2-wheel tractors , and you'll find lot of usefull information there.
