air compressor pressure switch
   / air compressor pressure switch #1
snapper
Bronze Member
I need to reset my pressure settings on my air compressor. I am not changing them just putting them back to spec. It has two bolts with a spring washer and nut on each. There are located one on one side then one on the other side.. any body know how to adjust this style??
Thanks so much..
   / air compressor pressure switch #2
one is for cut in pressure and the other is cut out. Look on the switch for markings. If none are found you will just have to experiment.
Unused 2025 CFG MX20R Mini Excavator (A50322)
Unused 2025 CFG...
John Deere 5075E (A50120)
John Deere 5075E...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
Ideal Applegate 180 gal Water Trough (A50515)
Ideal Applegate...
Land Honor Skid Steer Tree Puller (A50515)
Land Honor Skid...
KJ 33'x25' Double Garage Steel Barn Shed (A50121)
KJ 33'x25' Double...
