Air Cleaner Strap on BX
   / Air Cleaner Strap on BX #1
Tdog
Platinum Member
SE Louisiana
BX22
When I was checking the oil dipstick yesterday, I noticed a metal strap dangling over the top of the air cleaner canister. Anyone else had one of these break? Any idea how it could have happened?
   / Air Cleaner Strap on BX #2
Tdog, I'm going to try to post a link to another post that will answer your question.
If the link does not work, search for Kubota 2 Year Survey
I had the same problem with the broken air filter strap, and the thread gives the solution. Kubota 2 Year Survey
   / Air Cleaner Strap on BX #3
I have a BX1500 with 54 hours. Broke it last week, a day after it was in for its 50 hour service. My fix is a large tiewrap. /forums/images/graemlins/grin.gif
   / Air Cleaner Strap on BX #4
The way these little two cylinder engines vibrate at idle I am surprised more stuff doesn’t break off of them. At 20 some odd hours my air cleaner strap hasn’t broken yet, but then I try to keep the idle speed up a little to get above the bad vibration range. The engine mounts are amazing with how much of this vibration they can isolate from the frame.
   / Air Cleaner Strap on BX #5
Is this problem only on the BX 1500?? or does it also effect the BX 1800, 2200, & 22???? My BX 22 doesn't have any vibration in the engine to speak of..... very smooth, but it is a 3 cylinder
   / Air Cleaner Strap on BX #6
</font><font color="blue" class="small">( Is this problem only on the BX 1500?? or does it also effect the BX 1800, 2200, & 22???? My BX 22 doesn't have any vibration in the engine to speak of..... very smooth, but it is a 3 cylinder )</font>
The previous posters have BX22 and 2200s...looks like a BX problem regardless of size or engine.
   / Air Cleaner Strap on BX #7
I did have my hose become unattached. The vibration at low idle is pretty hard on a 2200, and I suspected (and I believe it has been comfirmed by others) that the 1500 would be very heavy.
It's a good idea to keep an eye out for this sort of stuff.
   / Air Cleaner Strap on BX #8
Yes the BX1500 rocks and rolls at idle. trying to get in the habit to keep it alittle above idle to smooth the vibration.
thanx, rlk & others. Somehow I missed those posts - - or I read it back then, but it wasn't relevant. I'll call my dealer tomorrow. Should be a warranty item.
   / Air Cleaner Strap on BX #10
My Bx-22 broke the strap; was replaced under warranty. 5 minutes to change it.
500 BBL FRAC TANK (A53843)
500 BBL FRAC TANK...
BAUER ATD-750 VERTICAL HYDRAULIC PIPE HANDLER (A53843)
BAUER ATD-750...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2016 Ford F-550 Service Truck (A53422)
2016 Ford F-550...
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
