Air Cleaner oil/dry? Six Cylinder Ford
   / Air Cleaner oil/dry? Six Cylinder Ford #1
401FordManNZ
New Zealand
Fords
Hi there,Would like your opinions on whether I can use my oilbath air cleaner or have to go dry for my 7810 engined 6600? Just was wondering if the extra cfm draw could pull some oil into the running engine? thanks:thumbsup:
   / Air Cleaner oil/dry? Six Cylinder Ford #3
hit a boneyard and find a dual element housing and slap that on using similar out port sizing for the pipe on the cleaner.
probably cheaper then buying a new replacement one.
soundguy
Thanks guys, I guess I'll go for a snoop in the breakers and see what I can find,I would ideally like a dry element that can be removed vertically so that I don't have to cut the hole in the front cowl...
   / Air Cleaner oil/dry? Six Cylinder Ford #5
the later series like my 7610s has a horizontal dual element housing up front under the flip up nose.
perhaps get one that you can remove the grill to access.. even if wet.. etc.
might look for something for a tw or big thousand series.
soundguy
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
2014 GMC Sierra 1500 Crew Cab Pickup Truck (A51692)
2014 GMC Sierra...
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
2014 Nissan Juke SUV (A51694)
2014 Nissan Juke...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2014 Nissan Pathfinder SUV (A53117)
2014 Nissan...
