Oil & Fuel Air Bleed Advice
   / Air Bleed Advice #1
Rebol
MF 40
Hello All,
I'm quite new to my my old tractor. I believe it to be a 70's era MF-40. I have to air bleed the critter (it's a long story) and I have some questions. I have a manual so it's not so much the general process but some specifics. Any help is most appreciated.
1. I am assuming the air vent plug is located on the fuel filter's "cap" top side. Mine is across from the fuel line and it looks like if you could reverse the cap then the fuel line would screw into it. So it's directly opposite that line. The only other bolt is on top and that holds the filter. Hopefully that's the one. The manual just assumes one knows where that is. Is that the correct bolt?
so far so good?
2. The pump is "conveniently" located on the other side so I can't see what goes on but when I pump it, I do get bubbles and then it slows down to some drips. The fuel never "gushes" out. Is it suppose to?
3. When you pump is it possible to actually introduce air? I noticed that if I go back and pump some more, more bubbles come out, then the drip. Should I keep repeating that until it eventually has no bubbles? Really it's this part I am stumped at. Also the very act of pumping might be an art. Do you all just pump very slowly?
4. After this I will move on to the lower and upper vent plugs on the injection pump. Thankfully there was a picture there.
5. The manual says to loosen "a" pressure line at the injection connection. There is one such connection that I can see and get to physically. I'm hoping I don't have to loosen any more before I crank it. Any thought?
Thanks in advance. I'd love to say I rescued my MF from its sorry state.
Rebol.
   / Air Bleed Advice #2
Welcome to TBN. You are on the right track. After you bleed it at the injector, try it to see if it will fire off. If it will not then crack the fitting at the injector 1/4 turn and crank it over about five or 6 seconds tighten the injector connections and then try it again. I usually did not have that difficult of a time in the bleed process on the Massey.
   / Air Bleed Advice
Thank you for the quick reply. I will try that.
And by the way, "Every one that is of the truth heareth my voice." I hear you brother.
   / Air Bleed Advice #4
Do you have to air bleed it every time? You shouldn't have to bleed it unless you run out of fuel or you have an air leak that is causing the fuel to siphon back to the tank. Edit: Any previously damp connection should be suspect for air problems.
   / Air Bleed Advice #5
I just crack the fitting on the return line going into the injection pump, turn the motor over until it fires, wait until there are no more air bubbles flowing past the fitting, and then tighten it up. It's not gasoline, so it wont flash ignite on you. Have lots of rags handy though.
   / Air Bleed Advice
Zork,
No, what happened was I took the kinds out for a ride and it had been raining a lot so when I hit a soft spot on a slight incline, the left tire sunk in bottomed out. I was also low on fuel at the same time (I bought this thing used and the gauge doesn't work). The angle she was left had her tilting to the side and I think that was enough to cause the problem when I tried to start her up again. Normally she fires up with no problems.
Anyway, it's really been a good way to learn about my tractor.
   / Air Bleed Advice
tcartwri,
Thank you. I will try that too. I appreciate the help.
   / Air Bleed Advice
OK,
Following some of your advice, I managed to get it running for a few seconds. I did the "crack the nut on the injector method" and noticed that while I eventually got it to stop bubbling, my suspicion is that there is still more air in the line.
Have any of you ever seen that before? I guess I just have to keep repeating the above method until it finally runs.
When you all have done this, is this what you experienced or did it work right away?
Thanks!
   / Air Bleed Advice #9
You may need to bleed each of the lines going to the injectors to. If you have all the air out to the pump there is still probably air between the pump and injectors. Its not hard just loosen the line at each injector one at a time while cranking it over. When that line starts spitting out fuel tighten the nut and move on to the next one.
   / Air Bleed Advice #10
If the cyl is firing (engine stumble with loose fuel line/picks up when line is tight) that air should be carried away through the bleed off lines on the top of the injector (if you have these). Once the system is relatively free of air it should eventually clear up via bleed hoses/lines. If you encounter the problem again; or additional major air you have a leak somewhere. All damp/cracked hoses and fittings should be suspect for air entrainment. Keep us posted.
2012 KALMAR 4X2 5TH WHEEL SPOTTER TRUCK (A51243)
2012 KALMAR 4X2...
Land Honor Portable Screener (A50514)
Land Honor...
2007 STERLING L9500 TANDEM AXLE DAY CAB (A52141)
2007 STERLING...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
