Ahat caulk to use for concrete patio/brick wall interface?
   / Ahat caulk to use for concrete patio/brick wall interface? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
What caulk to use for concrete patio/brick wall interface?
I've about 50 feet of brick house wall joined by concrete patio. It leaks. Apparently when built it wasn't done with proper flashing.
I've tried DAP Concrete and Mortar filler, that worked for a few years, but deteriorated.
The area gets strong sunlight from about noon on.
Any suggestions for a better product?
/edit it leaks between the wall and the concrete.
   / Ahat caulk to use for concrete patio/brick wall interface? #2
What/where is it leaking??...mortar joints? seam at the base of the brick wall?
The patio is poured up against the brick?
   / Ahat caulk to use for concrete patio/brick wall interface? #3
Proper flashing. Not cheap or easy but it sounds like you have trapped moisture that won’t be fixed with a chemical applied to the surface.
   / Ahat caulk to use for concrete patio/brick wall interface? #4
Your request raises a lot of questions. If water is coming through the walls mortar joints its a whole different issue. But to try to answer a question of a good caulk between concrete and brick check out URETHANE caulks. Several brands available at contractor and box stores. It’s available in a self leveling (consistency like thick syrup) or like normal caulk. Various colors also. Backer rod should be used.
If the gap is growing then nothing will hold up. Whatever you do keep silicone away. The area must be clean for best results. That includes previous failed products.
Warning, it will not come out or off your cloths, carpet, furniture, etc. best not to run it through a cloths dryer until its had several days to cure.
A couple of links to a couple of good brand names.
https://www.homedepot.com/p/Sikaflex-29-oz-Gray-Self-Leveling-Sealant-106711/202523824
https://www.acehardware.com/departments/paint-and-supplies/caulk-and-sealants/caulk/1508480
TITEBOND Gray Self-Leveling Concrete Floor Joint Sealant, 1.1 oz. Cartridge, Coverage':' 31 ft. '@' 1'/'4" x 1'/'4" - 2GXU1'|'3191 - Grainger
MasterSeal NP 1 elastomeric polyurethane sealant
MasterSeal SL 1
   / Ahat caulk to use for concrete patio/brick wall interface? #5
   / Ahat caulk to use for concrete patio/brick wall interface? #6
Any good urethane sealant needs a gap at least 1/4" wide X 1/2" deep with a backer rod or bond breaker tape at the bottom. For flat work I use the self leveling type and the standard for vertical. Vertical joints need to be tooled to assure bonding to both surfaces. As mentioned before, joint needs to be clean and dry, no dust either. OP may need to groove out along the wall with a vertical cut, then chip out.
Urethane has high elasticity to compensate for movement w/o failing. I always use SIKA products for sealants, they have several urethane base products. For DIY work stay away from the 2 part products.
To keep the dialog pure: Caulk/calk is an architecture cosmetic product (we call it 1" wide putty) and are designed to use with surface finishes. Sealants are just that, designed to seal against air or water. I have never seen Silicone work for very long unless sandwiched two surfaces mechanically joined (gasket). Movement, it fails and it does not bond well to surfaces.
Ron
   / Ahat caulk to use for concrete patio/brick wall interface? #7
   / Ahat caulk to use for concrete patio/brick wall interface? #8
Sika is good. I buy it at Lowes. I use it for filling cracks in brick and concrete.
I'm not sure that I understand the part about leaking. Where is the water going that is leaking? A picture would really be helpful.
2007 Mitsubishi Fuso FK61F 22ft Box Truck (A42742)
2007 Mitsubishi...
(2) Large Blast Mats (A42021)
(2) Large Blast...
2021 Chevrolet Tahoe FL SUV (A42744)
2021 Chevrolet...
2014 Ford F-550 IMT 7500-30 7,500LBS Crane Service Truck (A42742)
2014 Ford F-550...
2007 MACK CXN (VISION) (A45333)
2007 MACK CXN...
2019 KENWORTH T880 (A45046)
2019 KENWORTH T880...
