Agricultural/Agritech Bush Hog 5'
   / Agricultural/Agritech Bush Hog 5' #1
Rick1968
Conyers, GA
I searched the forums and found a lot of old information on the company. The problem I have is, I lost a blade yesterday and I need to know where I can get replacements. When I say lost, it slung through the side and got lost in the field and I can't find it. Any help will be greatly appreciated.
   / Agricultural/Agritech Bush Hog 5' #2
Well, if you do find new blades, and start mowing again, it doesn't sound like a good way to find the old one.
Try agri supply, they have a ton of aftermarket blades. Just select your make/model of mower. Better yet if you know the oem part number. It may be stamped on your other blade somewhere.
   / Agricultural/Agritech Bush Hog 5' #4
I dont buy blades by make and model. I shop by size.
Measure the one you have left. Width, thickness, length, offset, and hole diameter. Then match them up.
And would be best to replace both blades. If the one you have left has been sharpened alot, you will have a severe balance issue.
Appreciate all of the help and information. I will replace as a set but still hope to locate the lost one.
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
Ford Super Duty 8ft. Truck Bed (A51692)
Ford Super Duty...
2019 TEREX PHOENIX 2100 TROMMEL SCREEN (A53426)
2019 TEREX PHOENIX...
2010 JOHN DEERE 1110E FORWARDER (A51246)
2010 JOHN DEERE...
