Agri 72" 3pt Mower - Help
   / Agri 72" 3pt Mower - Help #1
shadled
South Central, PA
TC33DA w/14LA
Agri 72\" 3pt Mower - Help
This past weekend I picked up a slightly used Agri 72" 3pt Mower. The only problem with this mower is the plate which the gearbox attaches too is bent. So I need to remove the gear box. But before I can remove the gear box I need to remove the round spinner on the underside that the blades connect to. I removed the jam nut, but I am not sure what I need to remove next to get the round spinner off.. Does anyone have any ideas or a link to a manual for this mower.
Thanks,
Dennis
   / Agri 72" 3pt Mower - Help #2
Re: Agri 72\" 3pt Mower - Help
Hi Dennis,
Is this a Brush Hog/Rotary type mower or a finish mower. If its a rotary you might be able to go to King Kutters web and look at the rotary mower manuals. They MAY be constructed similarly.
Is this an AGRI Agri Fab and where's it made?
Curt
   / Agri 72" 3pt Mower - Help #3
Partially loosen the castle nut from the flywheel, until the end of the threads are protected on the outputshaft. Then while someone helps put down pressure on the flywheel, you hit the castle nut on the end of the shaft. This should break loos the flywheel from the tapered spline on the output shaft (sorta like removing a steering wheeel from a car)--Ken Sweet
Sweet Farm Equipment LLC *New Disc Mowers and Hay Tedders Ready to Ship*
I will give that a shot.. Thanks again for the help.
Dennis
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
2012 Ford F-250 4x4 Pickup Truck (A50323)
2012 Ford F-250...
Club Car Electric Golf Cart (A50121)
Club Car Electric...
2004 Dodge Ram 1500 4x4 SLT Crew Cab Pickup Truck (A50323)
2004 Dodge Ram...
2005 Chevrolet 3500 (A50120)
2005 Chevrolet...
