Tires Agracat/Jimna 200 tractor - one tire spin but the others don't move
   / Agracat/Jimna 200 tractor - one tire spin but the others don't move #1
brown2011
Oklahoma City, Oklahoma
AgraCat 200
I know little to nothing about a tractor. My AgraCat/Jimna 200 starts up fine and everything seems to work, that is until I put the tractor in gear and give it some gas. One tire spins but the other one don't. I am clueless! Do this sound like the brakes are locked up or something else? Can someone help me determine why my tractor won't move and how to correct the problem?
Thank you.:eek::confused::ashamed:
   / Agracat/Jimna 200 tractor - one tire spin but the others don't move #2
Well an open differential works like that with all the torque going to the wheel that can spin. Same thing happens when you are in a slippery situation, if one wheel can slip/spin the other wont... So I am assuming you are not on a slippery surface and one rear wheel is dragging across the ground/not moving and the other is turning/trying to push the tractor across the ground(in a circle)? As you guessed, that sounds like a stuck brake, or something is seriously broken inside where the rear differential and axles meet. Does it do it forward and reverse? Does the stuck wheel move at all when you switch from forward to reverse. Any movement when going from forward to reverse might indicate a gear problem. if it is frozen in place/no movement in either direction, I would say it is a stuck brake.
Where the brake linkages enter the axle housing is where the brakes are located. On the bottom of the brake housings are drain plugs. Remove them and see what comes out. you are hopeing they are dry and not full of water, but tractors who live out in the rain can sometimes fill up with water. Has also been known to happen in the clutch housing and it fuses the main and PTO clutch discs(also has a small drain plug)...
Do the brake pedals move? The Jinmas have a brake lock of sorts, it is a metal tab with notches on it that engage a pin on the brake pedal. Is that brake lock disengaged? If you follow the brake pedal linkages from the pedals back under to where they enter the rear axle housing, if the pedals are moving are the linkages also moving all the way into the housing?
These tractors also have split brakes, with a little metal tab that connects the two pedals together. These are to help you turn in sloppy conditions, or to apply brake force to a wheel that is spinning when you are stuck in the mud to send some torque to the wheel that has some traction and is not spinning, to help move the tractor(first generation traction control:)). This would be the first thing I would try if the brake linkages are moving. flip that little plate out of the way so the brake pedals operate independently, Start the tractor and in low range, first gear, step on the pedal for the wheel that is spinning, which will force some torque thru the differential to the wheel that is stuck. Try this forward and reverse and see if it gets something moving...
These tractors also have a rear differential lock(lever is behind right leg) but I would not use it for this as the mechanism that locks the axles together is a little fragile. I only use it when I am stuck and wheels are in a condition where they can definitely rotate and or slip...
Hi Ron,
Thank you for responding, I really appreciate it! No, the tractor is not on a slippery service. We first thought it was a stuck brake, but after I read a Jimna manual I thought it might be the differential lock. We messed around with it a bit and finally got all the tires to spin as they should. That took care of the problem. I am not sure how or why the differential lock was set to lock the tires, but hopefully this don't happen again. Thank you for all the info!
   / Agracat/Jimna 200 tractor - one tire spin but the others don't move #4
Hi Ron,
So "the differential was set to lock the tires" but only "One tire spins but the other one don't"? -That's exactly opposite of what should of happened if the differential lock was set.
...but the fix was "we messed around with it a bit" and it fixed itself. Nice!
I wish I was that lucky! :D
   / Agracat/Jimna 200 tractor - one tire spin but the others don't move #5
What Coby said, That dosnt make any sense. The difflock overrides the differential when engaged and ties the two axles together so they should both rotate at the same RPM. If one was spinning then the difflock could not be engaged. If you are stuck and one wheel is spinning because you do not have traction, the difflock will tie both wheels together to spin equally so the one that does have traction can move the tractor. The difflock lever is spring loaded to the off position so you have to hold it down/engaged, as you do not want to drive around with it on as it is hard on parts inside especially if you try and turn on a solid surface. With it engaged, it is hard to turn as the outside wheel cannot turn faster like when the differential is operating and the tires tear **** out of the ground.
I am learning as we go, the hard way. Thanks guys for your input!
2014 RAM 5500 Bucket Truck - 4X4 - Cummins Diesel - Automatic Transmission -Versalift SST40 Boom (A53472)
2014 RAM 5500...
ROADTEC RP-190E-3043 ASPHALT PAVER (A51246)
ROADTEC...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2012 WABASH 53x102 DRY VAN (A53426)
2012 WABASH 53x102...
2018 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2018 KOMATSU...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
