Ag Tires Up Front
   / Ag Tires Up Front #1
Mark Page
Platinum Member
Maryland
Massey Ferguson 2615 48hp, 4wd, loader
I'm still looking at new Masseys. Found a great deal on a 2615 4wd with ag tires all the way around. As I use the machine for finish mowing 70% of the time I'm concerned the ags will tear up the turf on turns. My current 231s has 4 rib tires up front and will tear up the grass if you don't slow way, way, way down. The ags on the rear have never been a problem.
   / Ag Tires Up Front #2
Last year I bought a NH T1510 with Ag tires. I use this tractor to blow snow. I live in the snowbelt of WNY, so I don't mean inches, I mean feet. I also mow about 3 acres with the tractor. After I tore up my lawn / field something fierce trying to mow with loaded Ag tires, I switched to loaded R-4 tires. Not too bad, but to be honest, not too good on a side hill, or going backwards in the snow. Not terrible, but not great. Still not happy, I switched to loaded turf and never looked back. MUCH better on the lawn / filed I mow, and, I don't know just why, but turf tires are WAY better in the snow than the R-4 tires I had. People that doubt this have never tried them. I have the Titan multi trac turfs. I have other tractors with Ag tires, so I can compare. Ag's probably the best in loose snow, then turfs, then R-4's. On the lawn it's turf, R-4's then Ag. Good luck.
   / Ag Tires Up Front #3
If your doing any type of mowing where appearance matters stay away from ag tires. You can get chains for those turf tires when you need them, and IMO the chains are easier to put on the turf tires.
   / Ag Tires Up Front #4
I have ags on all my tractors except one with r4s, but I could see where turfs with chains would dig better than anything the snow. Half of each cross link section is burried in the lugs of my ag tires at any given time. I don't use turfs because they aren't well suited for my uses, but they would be good for snow and mowing.
   / Ag Tires Up Front #5
Turfs are better in snow because their cleats are spaced closer. Contrary to popular belief, it is not the cleats providing most of the traction but the snow between the cleats against the snow on the ground providing the most tractive force. Auto snow tires are also designed to do the same thing.
   / Ag Tires Up Front #6
I don't base my front tire decisions on snow. It seems counter intuitive but most snow won't be the biggest steering challenge for the average tractor. For me it's muddy conditions. Unfortunately what works best in mud will be hard on grass.
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
Kubota BX2230D (A47384)
Kubota BX2230D...
2015 Ford Escape SUV (A51694)
2015 Ford Escape...
1997 CMC S102 END DUMP TRAILER (A53843)
1997 CMC S102 END...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A53843)
HYDRAULIC THUMB...
