Sprayer Ag sprayer advice
   / Ag sprayer advice #1
willywildes
SF bay area
3130 GST/ CAT D-2
I am looking for a sprayer mostly for Round up and the like. do i want a 3pt or trailer.Pto pump or elect. i am thinking in the 50 gallon size. I want a hand sprayer and maybe a short boom. any advice helpful
thanks WW
   / Ag sprayer advice #2
I use a 25 gal with 12v Shurflo pump, carried on a KK pallet mover on the 3PH. I expected it to marginal for my needs, but figured I'd take a chance and save the several hundred $$ compared to a 50 gal 3ph with PTO pump. To my surprise, the Shurflo pump and hand spray has worked very well. There are days that I put 100 gal of roundup through it.
   / Ag sprayer advice #3
I had the local co-op set me up with a 25 gal tank, electric pump, hoses, nozzles and tell me how to hook everything up with a length of gas pipe for the boom. I carry the tank in the FEL and "U" bolt the pipe with the nozzles on it to my lower links. I run wires from the pump to my battery. Works very well for my needs.
   / Ag sprayer advice #4
I have both a 25 gallon, tow behind sprayer with a 12 volt pump and a short boom that I use for herbicide and a 55 gallon single pole broadcast, PTO sprayer that I use for insecticide. For me it all depends on what your land is like. If it's relatively flat and smoothe, the tow behind works well but in the pasture, where it's much rougher, it tends to get beat up a bit. The 55 gallon PTO sprayer works anywhere although, with 450 pounds dangling off the back of my little tractor, it feels a little bit more "tippy" when I'm out in the pasture. Out in the pasture I prefer the 55 gallon sprayer because I dont have to waste time running back to the house to fill it up so often (basically, I guess I'm lazy). Around the house either one works well. I think the tow behind will cost more because of the trailer.
For herbicides I think I would prefer a tow behind because, with the boom and nozzles at a constant height, it's easier to get proper covereage. The PTO pump is more versatile because you can vary the pressure and coverage by adjusting the PTO rpm's. An electric, on demand pump works at a fixed pressure.
In the end it'll come down to personal preference, how you'll use it and cost. I know, I know, that's not much help, is it?
   / Ag sprayer advice #5
I have a 3pt Hardi PTO 30 gallon sprayer. I recently added a boom and three nozzles for pasture spraying. It has a 50 hose for the handgun. I use it mostly for spraying Roundup, Crossbow & Curtail. For uneven ground the 3pt is hard to beat. I went to a big ag sprayer supply place and they set me up way cheaper than a home and farm store. I know lots of satisfied folks who use the Sureflo 12v as well, especially off an atv. /forums/images/graemlins/blush.gif
   / Ag sprayer advice #6
I know that this is an old thread, but seemed like a good place to ask...
I want to build a sprayer. I need a boom to spray pasture and with the side booms flipped up near vertical, I need to spray Christmas trees. I am trying to decide on tank size.
How much pasture can you spray with a 25 gallon tank? I know that it varies some depending on what you're spraying. But just trying to get a ball park. Any good sites on building your own sprayer?
   / Ag sprayer advice #7
What do you want to spray? Yard, pasture??
   / Ag sprayer advice #8
I posted an inquiry regarding sprayers after your original one. Then I saw this one. My question is regarding spray nozzle types. (Boom or cluster) I have a Hahn Hi-Boy Ag sprayer with 450 gallon tank. I need a smaller one for yard work and spot spraying. I'm seriously looking at the 55 gallon Fimco sprayer at TSC. If you plan on using it much, get a rebuildable roller pump. PTO driven if you can justify the cost. My father used a 3 point 225 gallon sprayer on the farm for years. The ability to vary the booms distance off the ground is one strong point. Also, you can raise it up over some obsticles. The weight on the rear end of the tractor equates to traction with it mounted on the 3 point hitch (Provided you have a big enough tractor to carry that weight) I HIGHLY recommend 3 point sprayers. Get a "spot-spray gun". My only question is HOW ACCURATE ARE CLUSTER NOZZLES? /forums/images/graemlins/confused.gif
   / Ag sprayer advice #9
I did a search for sprayers and in another thread, chucko pointed to the TeeJet site. It is a wealth of information on nozzle selection, coverage areas, spray calibration, plumbing diagrams, datasheets, and selection & specification formulas. There may be other sites with similar info, but I found it very helpful.
   / Ag sprayer advice #10
Look at my post under the "roller pump" thread, re a 12v pump from TSC.
Ralph
2018 GMC Savana (A50120)
2018 GMC Savana...
2015 Jeep Renegade Latitude SUV (A50324)
2015 Jeep Renegade...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
EZGO GOLF CART (A50323)
EZGO GOLF CART...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
