Ag qd's
   / Ag qd's #1
2funkids
Bronze Member
Middleville, mi
Mahindra 3016 HST
Is it normal for AG type qd's to drip a little at the female ball seal?
   / Ag qd's #2
Not a constant drip. You'll get a wee bit of fluid when disconnecting but only if you've shut the tractor down, relieved the pressure on the hydraulic lines, then disconnect and put in the rubber cap.
I wouldn't recommend disconnecting whilst the tractor is running or you'll spray more fluid.
   / Ag qd's #3
Ya, they shouldn't leak when connected or disconnected. However they fill up with leaked fluid when connecting & more so when disconnecting. It oozes & drips out for a while after that.
   / Ag qd's #4
The QDs that have a ball for a shutoff will drip all the time, at least mine do. They have no O ring to seal them. The kind with a plunger instead of a ball have an O ring inside that seals the plunger so they don't drip. Others may have had a different experience.
   / Ag qd's
Thanks, I am finding this to be true. I built a small tray to catch the drips until I can upgrade.
   / Ag qd's #6
I've used these QC fittings both the ISO b and flat faced, very affordable and holding up well for me. FYI, the flat faced QC's are nice since they have virtually zero fluid loss on disconnect. Great if you connect/ disconnect regularly.
Bulk Hoses, Hydraulic Hose, Hose Fittings & Hose Adapters
2016 Ford Transit 350 Cargo Van (A50323)
2016 Ford Transit...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2012 Crane Carrier Low Entry Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
CPS 185 KD8 PORTABLE AIR COMPRESSOR (A52472)
CPS 185 KD8...
