Aftermarket seat for L4200??
   / Aftermarket seat for L4200?? #1
Jay4200
Veteran Member
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
My L4200's seat is getting really bad - the whole mechanism is rusty junk and needs to be replaced. I want to replace it with an aftermarket seat. Something nice with armrests and maybe suspension, but also reasonably priced. The mounting bracket looks a little weird though - it appears to go around a bump on the tin, so the typical aftermarket flat mount won't work (unless I build some kind of adapter). Any advice or suggestions?
JayC
   / Aftermarket seat for L4200?? #2
Watch for salvage equipment with cabs... the seats may be used up, and in need of replacement... But the suspension system under the seat will usually be in perfect condition. You can usually get those for little or nothing. Then all you will need is a seat to attach to it.
KennyV
KEWANCE 200 9' GRADER BLADE (A51243)
KEWANCE 200 9'...
2009 MINI Hardtop (A50324)
2009 MINI Hardtop...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
TEST YOUR BID BUTTON! (A51244)
TEST YOUR BID...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A52128)
2021 John Deere...
2017 John Deere 30G Mini Excavator (A50322)
2017 John Deere...
