Aftermarket Gaskets
   / Aftermarket Gaskets #1
Dataway
Greenfield TN
Ford 1715, BX2200
Is there a source for aftermarket NH gaskets as there is for the automotive market? I need the shifter cover gasket for my 1715 and the OEM piece is $40 ... kind of silly for a simple paper gasket.
   / Aftermarket Gaskets #3
Gasket in a tube or get out your scissors and go snip snip.
Not hard at all to do.
Smear some grease on the casing and press the paper/cardboard to create an outline and snip away.
I've don that many times, even keep raw stock on hand.
About the only gaskets that can't be DIY'd are head and exhaust.
Sounds like a plan, I still have my gasket hole cutters somewhere and a few roles of gasket materials.
   / Aftermarket Gaskets #5
Tricks I learned.
You lay the gasket material on the flat surface and gently tap a ball bearing 'ball' in the bolt hole area.
This effectively cuts a nice round hole just slightly oversize just where you need it to be.
Also pressing the gasket material I sort of see saw an Xacto blade around the inner and outer perimeters, works most times and better than scissors.
For paper gaskets I always found that greasing them really helped as they then were re-usable and also did not shift nor fall off during re assembly of components.
   / Aftermarket Gaskets #6
Or use never-sieze instead of grease. That is what they use on gaskets at work, it helps them seal and it makes them much easier to remove than ones put on with most other substances.
Aaron Z
44in Tooth Excavator Bucket (A51691)
44in Tooth...
1952 Jeep M38 (A51572)
Approximately 250 Traffic Cones (A51573)
Approximately 250...
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
WESSEX CRX 180 LOT NUMBER 171 (A53084)
WESSEX CRX 180 LOT...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
