Aftermarket FEL
   / Aftermarket FEL #1
pigdoc
Ames, IA
JD 2025R, Kubota ZD28
Looking at a 2013 Kubota B2920 HST 800 hours. Nice machine, but it has a Westendorf after market front end loader. Is there a problem with this FEL vs a factory one? Thanks in advance.
   / Aftermarket FEL #2
Westendorf is a reputable maker of aftermarket tractor attachments. Their loaders are widely used, and there is nothing wrong with having one on a tractor. A factory one will be specifically designed for a particular tractor, while an aftermarket loader is likely to be a more generic design with mounting hardware to let it be used on a variety of tractors. Kubota loaders generally have controls that operate quite smoothly and with a little practice make it easy to perform combination lift + curl moves, for example. An aftermarket loader may or may not be as refined. Something to evaluate during a test run.
I would also look at how easy it is to mount or remove the loader so the tractor can do certain chores without the FEL getting in the way, whether the bucket is a standard quick-attach type or a fixed, pin-on type. I'd want to be sure the loader controls are conveniently placed and also that the hydraulic lines and connections were added in a professional manner and the disconnects are secure but accessible.
   / Aftermarket FEL
Thanks for the response, this helps.
   / Aftermarket FEL #4
When I was a Kubota dealer, if you had an aftermarket loader on their tractor, and had a warranty problem, and there were many, they would refuse the warranty! I once had an L4200 break in half at the clutch housing, tractor was 6 months old! Kubota refused to pay because it had a Westendorf loader on it. Now that is embarrassing for a dealer. Clutch housing was paper thin.
   / Aftermarket FEL
I thought there might be some negative warranty aspects of this. But the tractor sold to someone else, so just a thought for the future. Thanks for the response.
   / Aftermarket FEL #6
That is crap. A loader is no different than any other implement. Kubota should be ashamed.
   / Aftermarket FEL #7
"That is crap. A loader is no different than any other implement. Kubota should be ashamed."
How do you know whether it's a bad tractor design, a bad loader design or an owner that beat the living **** out of the thing? If that model tractor works fine when an OEM loader is installed, you'd have to ask if the aftermarket loader was designed properly. If you look at the warranties offered by Kubota, Deere, Kioti and Mahindra (the ones I checked), they all have exclusions for damage resulting from use of non-approved attachments and some specifically mention non-OEM loaders and backhoes.
   / Aftermarket FEL #8
I had an aftermarket Stoll FEL installed on my 1720 New Holland several years ago. It was an FC 350 that was a good match for my tractor. The FEL brackets that attached the FEL to the tractor had 4 bolts on each side. That design was for the TC 30 which was the replacement for my 1720. The brackets would only allow for 3 bolts to attach on one of the sides. I didn't like it but that was an issue with the 1720 for that specific bracket design. In 5 years of ownership I had no issues with the tractor or FEL. The loader was rated to lift around 1K pounds and I think that my front axle was rated for 930# so it was a good match.
As Grandad4 stated most all manufacturers list non-OEM FEL's and backhoes as items that will void warranties.
   / Aftermarket FEL #9
I see a loader as an implement , no more no less.I sure would not like it if they refused to honor warranty if it were hooked to a plow,box blade,bushog or the like. A tractor is the base unit to handle tools in order to get work done.
   / Aftermarket FEL #10
Would a 2013 still have much warranty left? Anybody remember what the warranty length was then?
The B2920 is a good one if you come across another one. I have a 2008 I have had for 2.5 years with no issues.
Maybe you already know this but for your shopping purposes, if you come across a B2620, it is the same as the B2920 just 3 less HP.
2017 Hino 268 26FT Box Truck (A53422)
2017 Hino 268 26FT...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A54814)
2016 Ford F-550...
1996 FORD F SERIES DUMP TRUCK (A51406)
1996 FORD F SERIES...
2008 Ford F-450 14FT Flatbed Truck (A51692)
2008 Ford F-450...
CATERPILLAR 631G MOTOR SCRAPER (A52706)
CATERPILLAR 631G...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
