Aftermarket backhoe bucket
   / Aftermarket backhoe bucket #1
Raincoast
Powell River BC
Kioti ds4510 / kb2485 backhoe / KL401 loader
Hi folks.
I want to get a 9" bucket for stump removal & I noticed that Kioti doesn't make one. Are these CUT hoes built to an industry standard? Can anyone suggest a different manufacturer who makes a 9" bucket to fit?
Thanks. Dan
   / Aftermarket backhoe bucket #2
be careful on the smaller buckets, it can be much easier to "plug them up" with dirt. having suction holes / water holes built into bucket, can make a large difference.
might suggest a bucket with some teeth on it as well. so you can catch a root on one of the teeth. and pull on up and out. vs root sliding off of bucket.
larger backhoes the physical pins of were bucket attaches, might predict smallest size bucket recommended. other words no real reason to go with a bucket that is smaller width than the connection itself.
for myself i learned there are standardized sizes out there, but due to so many machines out there (backhoes, excavators, etc...) and more so different size machines mini's, to large size industrial units, including age of units. it kinda differ all over the place as far as standards. and in that you might need to use some spacers (basically large washers), or you may need to take bucket down to a local metal shop / welding shop. and get correct holes put in. (cut off / new welded on) to other.
might suggest listing your tractor make/model along with backhoe make/model
to note it, i have had to dig quite a bit for some larger trees. and i think it is 20" wide bucket, helped a good amount, just wish it was smaller for trenching, and a couple roots, though got away with it, made a bigger mess but got the job done.
trenching bucket, i would of preferred a flat edge bucket, vs a toothed bucket, to make bottoms a little more cleaner, but on other hand, not sure if i could of gotten through the initial hard compacted gravel driveway and a few other spots without a tooth bucket.
   / Aftermarket backhoe bucket #3
Check with Michigan Iron they make specialty buckets, ripper teeth etc. I am sure they would be of great help. They have made custom add ons for me quite reasonably.
They have banner add on this site.
   / Aftermarket backhoe bucket #4
Se MIE at Error this link does work
   / Aftermarket backhoe bucket #5
I bought my 9" for my 3054xs(KB 2376) from my Kioti dealer; came from Kioti with a Kioti UPC bar code, which has since been scrubbed off
   / Aftermarket backhoe bucket #6
Hi folks.
Thanks. Dan
What backhoe you have?
   / Aftermarket backhoe bucket #8
When I purchased my tractor I had the choice of a 9" or 12" bucket...so Kioti does make a 9" bucket.
MIE make a ripper that might suit your needs...
KIOTI KB2465/75 Backhoe Ripper (URT-50) - Hound Dog Attachments Backhoe Ripper Tooth KIOTI Backhoe Rippers
Not to get too far off topic here, but a ripper is great for stump removal. It focuses all the power on one spot and helps tear through the roots.
I've got one on my little BX23, and I love it. Mine is made by Bro-Tek, but I'm sure the MIE one is equally good.
Thanks guys... The 9" bucket is not available for my 2485 hoe, unfortunately. It is for the smaller hoes, though. I'll definitely look into a ripper bucket. Pity the manufacturers are so far from me. The shipping is a killer!
I just picked up the tractor today. Already knocked down the worst humps in the driveway (it's never looked so good) and got one big old fir stump loosened up. The 18" bucket is DEFINITELY not the best tool for that job!
Pretty steep learning curve on the hoe controls, but I'm catchin' on.
The tractor is a DS4510, by the way. I'll add that info to the side line as soon as I figger out the edit function. Duh.......
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A52748)
2006 Magnolia Dry...
BOBCAT 260 WELDER/GENERATOR (A52472)
BOBCAT 260...
Deere 9965 Cotton Picker (A52748)
Deere 9965 Cotton...
2024 BRAZOS  53FT ALUMINUM STEP DECK (A52472)
2024 BRAZOS 53FT...
