Aftermarket 9N Governor
   / Aftermarket 9N Governor #1
DJ54
Elite Member
Carroll, Ohio
IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
Was wondering if anyone has bought one of the aftermarket gov's for the 9N's, and if they have had any problems with them.
Trying to help an old buddy of mine in town that found out the little clip on the gov. shaft broke/wore through, and pretty much let it have pups internally. Knocked the corners off the flange where the 4 balls ride. Boogered the conical back half, the balls ride in. And the flange caught the balls, and kinda' put them into the gov. housing, dinging things up.
Looked up the parts at Ford New Holland, then aftermarket. For a few dollars more, you can get the complete gov. assy. brand new.
And was wondering if the little wire clip was a weak link in that unit. Happen often..?? Like, should that clip be replaced if you ever overhaul the tractor?? I see now they use probably an updated version of what was made then, a C-clip. F/NH say's to procure locally.
Didn't think to ask if that groove is worn, or distorted since it let loose. If it is, then no use putting new internals in without putting the new shaft in, and having more in it than the complete unit.
   / Aftermarket 9N Governor #2
if the back cap is bad.. just get a reman or new repalcement gov and be done with it IMHO..
That's what we were thinking... Found a complete new assy. for less than a reman'd.
Can't believe the different prices, on what's probably the same unit, from the same mfg. WOW..!!
   / Aftermarket 9N Governor #4
yep. pays to shop around. I see vastly different prices on parts all from the same manufacturer.. etc. ( or importer anyway.. :) )
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
2016 John Deere 326E (A47477)
2016 John Deere...
Unused Delta Crash...
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
