After-market ROPS
   / After-market ROPS #1
K7CSM
Where can I find a ROPS for an Iseki TL2100? Also, does anyone know what weight oil is best for the transmission? I asked the guy I bought it from and he said 10w hydraulic oil. Doesn't seem to make sense. I would think transmissions on tractors would be about the same as a manual transmission on a truck. They normally require 75w-90w gear oil. Any help on these two items will be appreciated.
Tom Detchemendy - K7CSM - The Lead Sled Dog
   / After-market ROPS #2
Not familiar with the Iseki, but most tractors use hydraulic fluid in the transmission, not gear oil. Make sure what you need before you put anything in it.
If you scroll down farther, there is an Iseki forum under other brands. Try you questions there.
   / After-market ROPS #3
I agree with BBTx, most tractors that use a common sump for hydraulics, tranny and diffy.. use a universal transdraulic oil... Though some of the very old fords in the 30's - 50's used a 90 wt mineral gear oil in their common sump.. BUT their hydr pump was made for that heavy oil...
Try to find some manufacturer specs..
Soundguy
City of Buckhannon - 2005 Volvo Garbage Truck (A52384)
City of Buckhannon...
UNUSED CFG MX15RX EXCAVATOR (A51247)
UNUSED CFG MX15RX...
UNUSED RAYTREE RMSG-29 29" STUMP GRINDER (A51248)
UNUSED RAYTREE...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
TAKEUCHI TL230 SERIES 2 SKID STEER (A51246)
TAKEUCHI TL230...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
