After market replacement cylinders for JD 300 class loaders
   / After market replacement cylinders for JD 300 class loaders #1
mkr7734
The North Bluff above Marseilles IL
John Deere 3203,
Is there anyone out there that makes replacement cylinders for John Deere 300 class loaders?
John Deere is awful proud of theirs at over $600 each.
Tks,
Kev.
   / After market replacement cylinders for JD 300 class loaders #2
Might contact a local hydraulic repair shop. If JD did not make the cylinders a unique size you should be able to find a suitable replacement.
Is the cylinder beyond rebuilding?
Mine are fine, I just want to up-grade from 300 cylinders to 300X cylinders for more lift and can't see spending $1.200 to do it. Or afford it.
   / After market replacement cylinders for JD 300 class loaders #4
How much more lift would you get? Might consider upping the pressure with shims on the relief valves to increase lift with the current cylinders.
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2016 VOLVO VNL300 TANDEM AXLE DAY CAB (A52576)
2016 VOLVO VNL300...
Duetz Power Unit (A50120)
Duetz Power Unit...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
2015 INTERNATIONAL MA025 (A52472)
2015 INTERNATIONAL...
2021 TAKEUCHI TL8R2 SKID STEER (A51246)
2021 TAKEUCHI...
