Aerator/Dethatcher for BX24
   / Aerator/Dethatcher for BX24 #1
donn12
Platinum Member
Great Falls Virginia
B2920 TLB turfs and loaded ags
Any recommendations? I have done several searches and now i am more confused.
   / Aerator/Dethatcher for BX24 #4
Is this for personal or professional use?? Professional units run $1500ish i believe.. Personal units can be gotten for under $200
I have been using a friends pull behind 48" Sears aerator for the past few years and it does an excellent job for my yard.. I typically aerate 2 to 3 times a year and i get up to 3" plugs (with about 120# of weight) depending on how wet it is.. I just cant justify much more expense for what I amdoing with it..
good luck
Brian
I actually need both an aerator and a dethatcher. I am only using this for my 2 acres but I do want decent units I can use for a long time.
Are some of the drag behind harrow type units good for dethatching?
thanks
   / Aerator/Dethatcher for BX24 #6
Paul, any idea of what that Landpride unit costs?? Thanks
   / Aerator/Dethatcher for BX24 #7
A used 2004 Landpride CA25-48" core aerator sold for $1,750 at auction...
   / Aerator/Dethatcher for BX24 #8
I bought a dethatcher at Agr Supply about a year ago. It's very cheap, about $100, and is pulled from the drawbar. You CANNOT back up with this device. It'll bend the hitch. Otherwise, it works fine for dethatching.
Around here, you can rent a core aerator, 3 different kinds. One of them includes one for the 3 ph. It's a heavy looking beast. My 4010 will probably handle it. My problem is no way to get it home. It's just a tad large to just put inside the gate in the back of my Tacoma. That way, I could just hitch up to it with the 4010 with the Tacoma backed to the ramp that goes up into my carriage house.
Core aerators are used so infrequently that renting is a good option to check out.
Ralph
   / Aerator/Dethatcher for BX24 #9
Around me they only rent the self powered BlueBird aerators and they run around $60 for a 3 hour rental. I actually rented one a couple of weekends ago and it is very tiring machine to use as it basically drags you along behind it. A tractor pulled one is not available for rent in my area.
This is the rental/homeowner model of the machine I plan on purchasing and it runs $300. I figure 5 rentals of the machine above would cost me the same so I might as well buy one. I plan on aerating twice a year (Spring/Fall). Rental/Residential Core Aerator
2015 KIA Cadenza (A50324)
2015 KIA Cadenza...
Komatsu PC490LC-11 Hydraulic Excavator (A49346)
Komatsu PC490LC-11...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2018 FREIGHLTINER CASCADIA TANDEMA AXLE SLEEPER (A52141)
2018 FREIGHLTINER...
EZ-GO GOLF CART (A51243)
EZ-GO GOLF CART...
International 4700 Vibra Tiller (A51039)
International 4700...
